FIX: Always backup local uploads in addition to files stored on S3
diff --git a/lib/backup_restore/backuper.rb b/lib/backup_restore/backuper.rb
index d93ac58..1306d36 100644
--- a/lib/backup_restore/backuper.rb
+++ b/lib/backup_restore/backuper.rb
@@ -252,11 +252,8 @@ module BackupRestore
-      if SiteSetting.Upload.enable_s3_uploads
-        add_remote_uploads_to_archive(tar_filename)
-      else
-        add_local_uploads_to_archive(tar_filename)
-      end
+      add_local_uploads_to_archive(tar_filename)
+      add_remote_uploads_to_archive(tar_filename) if SiteSetting.Upload.enable_s3_uploads
       remove_tmp_directory
@@ -280,7 +277,7 @@ module BackupRestore
             failure_message: "Failed to archive uploads.", success_status_codes: [0, 1]
         else
-          log "No uploads found, skipping archiving uploads..."
+          log "No local uploads found. Skipping archiving of local uploads..."
@@ -323,7 +320,7 @@ module BackupRestore
-      log "No uploads found, skipping archiving uploads..." if count == 0
+      log "No uploads found on S3. Skipping archiving of uploads stored on S3..." if count == 0
     def upload_archive
GitHub sha: b73bd7fc
