FIX: always force tl0 for public
diff --git a/assets/javascripts/lib/raw-event-helper.js.es6 b/assets/javascripts/lib/raw-event-helper.js.es6
index c24b7d4..ed54346 100644
--- a/assets/javascripts/lib/raw-event-helper.js.es6
+++ b/assets/javascripts/lib/raw-event-helper.js.es6
@@ -33,6 +33,10 @@ export function buildParams(startsAt, endsAt, eventModel) {
     params.allowedGroups = (eventModel.raw_invitees || []).join(",");
+  if (eventModel.status === "public") {
+    params.allowedGroups = "trust_level_0";
   if (eventModel.reminders && eventModel.reminders.length) {
     params.reminders = eventModel.reminders
       .map(r => `${r.value}.${r.unit}`)
GitHub sha: e0247293
