FIX: amend resetting of cache
We need to reset the column info cache for posts so we can run the update
diff --git a/db/migrate/20200226183018_create_calendar_events.rb b/db/migrate/20200226183018_create_calendar_events.rb
index 3261640..d116ca7 100644
--- a/db/migrate/20200226183018_create_calendar_events.rb
+++ b/db/migrate/20200226183018_create_calendar_events.rb
@@ -33,9 +33,9 @@ class CreateCalendarEvents < ActiveRecord::Migration[5.2]
       SQL
       # this is not ideal we should be using SQL here but this will work around bad schema
-      ActiveRecord::Base.clear_cache!
+      ActiveRecord::Base.connection.query_cache.clear
+      Post.reset_column_information
       Post.where(topic_id: calendar_topic_ids).each { |post| CalendarEvent.update(post) }
       execute "DELETE FROM post_custom_fields WHERE name = 'calendar-details' OR name = 'calendar-holidays'"
     rescue => e
GitHub sha: 97de973e
