FIX: Apply category priority for empty query (PR #9516)
This PR is to apply category search priority when searching with empty query without specified order.
Per https://meta.discourse.org/t/search-priority-for-categories-dont-work-with-empty-search-query/143642
GitHub
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
https://meta.discourse.org/t/search-priority-for-categories-dont-work-with-empty-search-query/143642/3
Could you add some tests for this?
Sure, I will add tests for this later.
Sorry for the late reply. I have added some tests, please check my update :smile:
Thanks, this looks good now! I’m going to merge it.
@blueworrybear : Does this fix ensure proper behavior of queries like this too? https://meta.discourse.org/search?q=status%3Asingle_user%20status%3Aopen%20status%3Aunsolved%20order%3Alatest_topic
That was actually my original question when I said empty query (but with search parameters).
@blueworrybear : Does this fix ensure proper behavior of queries like this too? Search results for 'status:single_user status:open status:unsolved order:latest_topic' - Discourse Meta
@GokulNC
The queries you posted will still sort by the topic created time.
The topics will be sorted by priority only if the order is not specified.
For example:
This query will sort topics with priority.
Got it, thanks a lot !! :slight_smile:
