FIX: `approve post count` did not take new topics into account
FIX: approve post count did not take new topics into account
This means if a user created a new topic, and it was approved, it would not count towards their approval count. Replies worked correctly.
diff --git a/lib/new_post_manager.rb b/lib/new_post_manager.rb
index 081e6e5..3f2f63e 100644
--- a/lib/new_post_manager.rb
+++ b/lib/new_post_manager.rb
@@ -88,7 +88,7 @@ class NewPostManager
     return :post_count if (
       user.trust_level <= TrustLevel.levels[:basic] &&
-      user.post_count < SiteSetting.approve_post_count
+      (user.post_count + user.topic_count) < SiteSetting.approve_post_count
     return :trust_level if user.trust_level < SiteSetting.approve_unless_trust_level.to_i
diff --git a/spec/components/new_post_manager_spec.rb b/spec/components/new_post_manager_spec.rb
index e8f6fa1..65cbe56 100644
--- a/spec/components/new_post_manager_spec.rb
+++ b/spec/components/new_post_manager_spec.rb
@@ -71,6 +71,32 @@ describe NewPostManager do
+    context 'basic post/topic count restrictions' do
+      before do
+        SiteSetting.approve_post_count = 1
+      end
+      it "works with a correct `user_stat.post_count`" do
+        result = NewPostManager.default_handler(manager)
+        expect(result.action).to eq(:enqueued)
+        expect(result.reason).to eq(:post_count)
+        manager.user.user_stat.update(post_count: 1)
+        expect(result).to eq(nil)
+      end
+      it "works with a correct `user_stat.topic_count`" do
+        manager.user.user_stat.update(topic_count: 1)
+      end
+    end
     context 'with a high approval post count and TL0' do
       before do
         SiteSetting.approve_post_count = 100
GitHub sha: add3d46b
https://meta.discourse.org/t/my-approve-post-count-isnt-working-when-set-to-1/163185/6
