FIX: automatically expire bad push channels (#13156)
Previously we would retry push notifications indefinitely for all errors except for ExpiredSubscription
Under certain conditions other persistent errors may arise such as a persistent rate limit.
If we track more than 3 errors in a period of time longer than a day we will delete the subscription
Also performs a bit of internal cleanup to ensure protected methods really are private.
diff --git a/app/models/push_subscription.rb b/app/models/push_subscription.rb
index 1c012d8..dffdab1 100644
--- a/app/models/push_subscription.rb
+++ b/app/models/push_subscription.rb
@@ -2,15 +2,21 @@
 class PushSubscription < ActiveRecord::Base
   belongs_to :user
+  def parsed_data
+    JSON.parse(data)
+  end
 # == Schema Information
 # Table name: push_subscriptions
-#  id         :bigint           not null, primary key
-#  user_id    :integer          not null
-#  data       :string           not null
-#  created_at :datetime         not null
-#  updated_at :datetime         not null
+#  id            :bigint           not null, primary key
+#  user_id       :integer          not null
+#  data          :string           not null
+#  created_at    :datetime         not null
+#  updated_at    :datetime         not null
+#  error_count   :integer          default(0), not null
+#  first_error_at :datetime
diff --git a/app/services/push_notification_pusher.rb b/app/services/push_notification_pusher.rb
index 4e013a8..72000de 100644
--- a/app/services/push_notification_pusher.rb
+++ b/app/services/push_notification_pusher.rb
@@ -22,7 +22,6 @@ class PushNotificationPusher
       subscriptions(user).each do |subscription|
-        subscription = JSON.parse(subscription.data)
         send_notification(user, subscription, message)
@@ -66,8 +65,6 @@ class PushNotificationPusher
     PushSubscription.find_by(user: user, data: subscription.to_json)&.destroy!
-  protected
   def self.get_badge
     if (url = SiteSetting.site_push_notifications_icon_url).present?
       url
@@ -76,13 +73,30 @@ class PushNotificationPusher
+  MAX_ERRORS ||= 3
+  MIN_ERROR_DURATION ||= 86400 # 1 day
+  def self.handle_generic_error(subscription)
+    subscription.error_count += 1
+    subscription.first_error_at ||= Time.zone.now
+    delta = Time.zone.now - subscription.first_error_at
+    if subscription.error_count >= MAX_ERRORS && delta > MIN_ERROR_DURATION
+      subscription.destroy!
+    else
+      subscription.save!
+    end
+  end
   def self.send_notification(user, subscription, message)
-    endpoint = subscription["endpoint"]
-    p256dh = subscription.dig("keys", "p256dh")
-    auth = subscription.dig("keys", "auth")
+    parsed_data = subscription.parsed_data
+    endpoint = parsed_data["endpoint"]
+    p256dh = parsed_data.dig("keys", "p256dh")
+    auth = parsed_data.dig("keys", "auth")
     if (endpoint.blank? || p256dh.blank? || auth.blank?)
-      unsubscribe(user, subscription)
       return
@@ -99,22 +113,31 @@ class PushNotificationPusher
           expiration: TOKEN_VALID_FOR_SECONDS
+      if subscription.first_error_at || subscription.error_count != 0
+        subscription.update_columns(error_count: 0, first_error_at: nil)
+      end
     rescue Webpush::ExpiredSubscription
     rescue Webpush::ResponseError => e
       if e.response.message == "MismatchSenderId"
       else
+        handle_generic_error(subscription)
         Discourse.warn_exception(
           e,
           message: "Failed to send push notification",
           env: {
             user_id: user.id,
-            endpoint: subscription["endpoint"],
+            endpoint: endpoint,
             message: message.to_json
+  private_class_method :send_notification
+  private_class_method :handle_generic_error
diff --git a/db/migrate/20210526053611_add_error_count_to_push_subscriptions.rb b/db/migrate/20210526053611_add_error_count_to_push_subscriptions.rb
new file mode 100644
index 0000000..632b510
--- /dev/null
+++ b/db/migrate/20210526053611_add_error_count_to_push_subscriptions.rb
@@ -0,0 +1,8 @@
+class AddErrorCountToPushSubscriptions < ActiveRecord::Migration[6.1]
+  def change
+    add_column :push_subscriptions, :error_count, :integer, null: false, default: 0
+    add_column :push_subscriptions, :first_error_at, :datetime
+  end
+end
diff --git a/spec/services/push_notification_pusher_spec.rb b/spec/services/push_notification_pusher_spec.rb
index de16592..f00d3ab 100644
--- a/spec/services/push_notification_pusher_spec.rb
+++ b/spec/services/push_notification_pusher_spec.rb
@@ -19,18 +19,20 @@ RSpec.describe PushNotificationPusher do
   it "sends notification in user's locale" do
     SiteSetting.allow_user_locale = true
     user = Fabricate(:user, locale: 'pt_BR')
-    PushSubscription.create!(user_id: user.id, data: "{\"endpoint\": \"endpoint\"}")
-    PushNotificationPusher.expects(:send_notification).with(user, { "endpoint" => "endpoint" }, {
-      title: "system mencionou vocĂȘ em \"Topic\" - Discourse",
-      body: "description",
-      badge: "/assets/push-notifications/discourse.png",
-      icon: "/assets/push-notifications/mentioned.png",
-      tag: "test.localhost-1",
-      base_url: "http://test.localhost",
-      url: "https://example.com/t/1/2",
-      hide_when_active: true
-    }).once
+    data = <<~JSON
+        "endpoint": "endpoint",
+        "keys": {
+          "p256dh": "p256dh",
+          "auth": "auth"
+    JSON
+    PushSubscription.create!(user_id: user.id, data: data)
+    Webpush.expects(:payload_send).with do |*args|
+      args.to_s.include?("system mencionou")
+    end.once
     PushNotificationPusher.push(user, {
       topic_title: 'Topic',
@@ -42,6 +44,60 @@ RSpec.describe PushNotificationPusher do
+  it "deletes subscriptions which are erroring regularly" do
+    start = freeze_time
+    user = Fabricate(:user)
+    data = <<~JSON
+        "keys": {
+          "auth": "auth"
+    JSON
+    sub = PushSubscription.create!(user_id: user.id, data: data)
+    response = Struct.new(:body, :inspect, :message).new("test", "test", "failed")
+    error = Webpush::ResponseError.new(response, "localhost")
+    Webpush.expects(:payload_send).raises(error).times(4)
+    # 3 failures in more than 24 hours
+    3.times do
+      PushNotificationPusher.push(user, {
+        topic_title: 'Topic',
+        username: 'system',
+        excerpt: 'description',
+        topic_id: 1,
+        post_url: "https://example.com/t/1/2",
+        notification_type: 1
+      freeze_time 1.minute.from_now
+    end
+    sub.reload
+    expect(sub.error_count).to eq(3)
+    expect(sub.first_error_at).to eq_time(start)
+    freeze_time(2.days.from_now)
+      topic_id: 1,
+    expect(PushSubscription.where(id: sub.id).exists?).to eq(false)
+  end
   it "deletes invalid subscriptions during send" do
     user = Fabricate(:walter_white)
GitHub sha: d4568271
This commit appears in #13156 which was approved by ZogStriP. It was merged by SamSaffron.
