FIX: Better error handling if a file cannot be sent
If for some reason Discourse.store.path_for returns nil, the forum would throw an error rather than returning 404.
Why would it be nil? One cause could be changing the type of file store and having the url field no longer be relative.
diff --git a/app/controllers/uploads_controller.rb b/app/controllers/uploads_controller.rb
index 64d08d4..481d5d9 100644
--- a/app/controllers/uploads_controller.rb
+++ b/app/controllers/uploads_controller.rb
@@ -75,7 +75,11 @@ class UploadsController < ApplicationController
         opts[:disposition]   = "inline" if params[:inline]
         opts[:disposition] ||= "attachment" unless FileHelper.is_supported_image?(upload.original_filename)
-        send_file(Discourse.store.path_for(upload), opts)
+        file_path = Discourse.store.path_for(upload)
+        return render_404 unless file_path
+        send_file(file_path, opts)
       else
         render_404
diff --git a/spec/requests/uploads_controller_spec.rb b/spec/requests/uploads_controller_spec.rb
index db79aab..9128d85 100644
--- a/spec/requests/uploads_controller_spec.rb
+++ b/spec/requests/uploads_controller_spec.rb
@@ -226,6 +226,14 @@ describe UploadsController do
       expect(response.status).to eq(404)
+    it "returns 404 when the path is nil" do
+      upload = upload_file("logo.png")
+      upload.update_column(:url, "invalid-url")
+      get "/uploads/#{site}/#{upload.sha1}.#{upload.extension}"
+      expect(response.status).to eq(404)
+    end
     it 'uses send_file' do
GitHub sha: 6f656f6e
