FIX: Broken spec
FIX: Broken spec
diff --git a/spec/components/hijack_spec.rb b/spec/components/hijack_spec.rb
index f99d71f..a0ef15e 100644
--- a/spec/components/hijack_spec.rb
+++ b/spec/components/hijack_spec.rb
@@ -109,7 +109,7 @@ describe Hijack do
     expected = {
       "Access-Control-Allow-Origin" => "www.rainbows.com",
-      "Access-Control-Allow-Headers" => "Content-Type, Cache-Control, X-Requested-With, X-CSRF-Token, Discourse-Visible, User-Api-Key, User-Api-Client-Id",
+      "Access-Control-Allow-Headers" => "Content-Type, Cache-Control, X-Requested-With, X-CSRF-Token, Discourse-Visible, User-Api-Key, User-Api-Client-Id, Authorization",
       "Access-Control-Allow-Credentials" => "true",
       "Access-Control-Allow-Methods" => "POST, PUT, GET, OPTIONS, DELETE"
diff --git a/yarn.lock b/yarn.lock
index 8f4e935..48534aa 100644
--- a/yarn.lock
+++ b/yarn.lock
@@ -1544,7 +1544,12 @@ linkify-it@^2.0.0:
     semver "5.3.0"
     uglify-js "2.7.5"
-lodash@4.17.14, lodash@^4.17.11, lodash@^4.17.4, lodash@^4.2.0, lodash@^4.3.0:
+lodash@4.17.15:
+  version "4.17.15"
+  resolved "https://registry.yarnpkg.com/lodash/-/lodash-4.17.15.tgz#b447f6670a0455bbfeedd11392eff330ea097548"
+  integrity sha512-8xOcRHvCjnocdS5cpwXQXVzmmh5e5+saE2QGoeQmbKmRS6J3VQppPOIt0MnmE+4xlZoumy0GPG0D0MVIQbNA1A==
+lodash@^4.17.11, lodash@^4.17.4, lodash@^4.2.0, lodash@^4.3.0:
   version "4.17.14"
   resolved "https://registry.yarnpkg.com/lodash/-/lodash-4.17.14.tgz#9ce487ae66c96254fe20b599f21b6816028078ba"
   integrity sha512-mmKYbW3GLuJeX+iGP+Y7Gp1AiGHGbXHCOh/jZmrawMmsE7MS4znI3RL2FsjbqOyMayHInjOeykW7PEajUk1/xw==
GitHub sha: ddd45d14
Was the lodash upgrade also part of the broken build?
No, I think our post-commit hooks did that and I committed it accidentally.
I’m not sure if it’s worth reverting that part or just leaving it since it’s a minor upgrade that doesn’t seem to have caused any issues so far.
