FIX: bufferedValuesString.split is not a function (PR #8463)
Fix an error bufferedValuesString.split is not a function. It is happening when bufferedValue is a positive boolean (checkbox value)
GitHub
You’ve signed the CLA, lis2. Thank you! This pull request is ready for review.
The interesting thing I see here is that both computed properties have the exact same definition if you ignore variables names.
function splitPipes(str) {
  if (typeof str === "string") {
      return str.split("|").filter(Boolean);
    } else {
      return [];
And then:
@discourseComputed('buffered.value')
bufferedValues: splitPipes,
@discourseComputed('setting.defaultValues')
This looks good to merge to me, pending Robin’s neat refactor.
@eviltrout nice one, thank you, fixed
