FIX: Call `_clearFlash()` when displaying a modal (#14848)
FIX: Call _clearFlash() when displaying a modal (#14848)
d-modal-body.js was setting the text of a modal-alert element to "", but not removing any classes on that element. Changing this to call _clearFlash() ensures that a variety of styling classes are also removed from the element, which prevents empty alert elements being included on any subsequent modals that are displayed.
Several other controllers have also been modified to change the class of the error from alert-error to error. The alert-is unnecessary, as it is added by_flash(msg)withind-modal-body.js`.
diff --git a/app/assets/javascripts/discourse/app/components/d-modal-body.js b/app/assets/javascripts/discourse/app/components/d-modal-body.js
index 1e46c44..4231de2 100644
--- a/app/assets/javascripts/discourse/app/components/d-modal-body.js
+++ b/app/assets/javascripts/discourse/app/components/d-modal-body.js
@@ -10,7 +10,7 @@ export default Component.extend({
     this._super(...arguments);
     this._modalAlertElement = document.getElementById("modal-alert");
     if (this._modalAlertElement) {
-      this._modalAlertElement.innerHTML = "";
+      this._clearFlash();
     let fixedParent = $(this.element).closest(".d-modal.fixed-modal");
diff --git a/app/assets/javascripts/discourse/app/controllers/change-owner.js b/app/assets/javascripts/discourse/app/controllers/change-owner.js
index 96db63e..d317a6c 100644
--- a/app/assets/javascripts/discourse/app/controllers/change-owner.js
+++ b/app/assets/javascripts/discourse/app/controllers/change-owner.js
@@ -50,7 +50,7 @@ export default Controller.extend(ModalFunctionality, {
-          this.flash(I18n.t("topic.change_owner.error"), "alert-error");
+          this.flash(I18n.t("topic.change_owner.error"), "error");
           this.set("saving", false);
diff --git a/app/assets/javascripts/discourse/app/controllers/change-timestamp.js b/app/assets/javascripts/discourse/app/controllers/change-timestamp.js
index 0791540..56957a1 100644
--- a/app/assets/javascripts/discourse/app/controllers/change-timestamp.js
+++ b/app/assets/javascripts/discourse/app/controllers/change-timestamp.js
@@ -54,7 +54,7 @@ export default Controller.extend(ModalFunctionality, {
           next(() => DiscourseURL.routeTo(topic.url));
         .catch(() =>
-          this.flash(I18n.t("topic.change_timestamp.error"), "alert-error")
+          this.flash(I18n.t("topic.change_timestamp.error"), "error")
         .finally(() => this.set("saving", false));
diff --git a/app/assets/javascripts/discourse/app/controllers/delete-topic-confirm.js b/app/assets/javascripts/discourse/app/controllers/delete-topic-confirm.js
index f310161..eb5496e 100644
--- a/app/assets/javascripts/discourse/app/controllers/delete-topic-confirm.js
+++ b/app/assets/javascripts/discourse/app/controllers/delete-topic-confirm.js
@@ -29,7 +29,7 @@ export default Controller.extend(ModalFunctionality, {
       .destroy(this.currentUser)
       .then(() => this.send("closeModal"))
       .catch(() => {
-        this.flash(I18n.t("post.controls.delete_topic_error"), "alert-error");
+        this.flash(I18n.t("post.controls.delete_topic_error"), "error");
         this.set("deletingTopic", false);
diff --git a/app/assets/javascripts/discourse/app/controllers/edit-topic-timer.js b/app/assets/javascripts/discourse/app/controllers/edit-topic-timer.js
index b3ca2cd..50e30cd 100644
--- a/app/assets/javascripts/discourse/app/controllers/edit-topic-timer.js
+++ b/app/assets/javascripts/discourse/app/controllers/edit-topic-timer.js
@@ -185,7 +185,7 @@ export default Controller.extend(ModalFunctionality, {
         this.flash(
           I18n.t("topic.topic_status_update.time_frame_required"),
-          "alert-error"
+          "error"
         return;
@@ -195,19 +195,13 @@ export default Controller.extend(ModalFunctionality, {
         !this.get("topicTimer.updateTime")
         if (this.get("topicTimer.duration_minutes") <= 0) {
-          this.flash(
-            I18n.t("topic.topic_status_update.min_duration"),
-            "alert-error"
+          this.flash(I18n.t("topic.topic_status_update.min_duration"), "error");
           return;
         // cannot be more than 20 years
         if (this.get("topicTimer.duration_minutes") > 20 * 365 * 1440) {
-          this.flash(
-            I18n.t("topic.topic_status_update.max_duration"),
-            "alert-error"
+          this.flash(I18n.t("topic.topic_status_update.max_duration"), "error");
           return;
diff --git a/app/assets/javascripts/discourse/app/controllers/ignore-duration-with-username.js b/app/assets/javascripts/discourse/app/controllers/ignore-duration-with-username.js
index b142e37..2d92d73 100644
--- a/app/assets/javascripts/discourse/app/controllers/ignore-duration-with-username.js
+++ b/app/assets/javascripts/discourse/app/controllers/ignore-duration-with-username.js
@@ -13,7 +13,7 @@ export default Controller.extend(ModalFunctionality, {
       if (!this.ignoredUntil || !this.ignoredUsername) {
         this.flash(
           I18n.t("user.user_notifications.ignore_duration_time_frame_required"),
-          "alert-error"
+          "error"
         return;
diff --git a/app/assets/javascripts/discourse/app/controllers/ignore-duration.js b/app/assets/javascripts/discourse/app/controllers/ignore-duration.js
index ad141ae..28d8ee2 100644
--- a/app/assets/javascripts/discourse/app/controllers/ignore-duration.js
+++ b/app/assets/javascripts/discourse/app/controllers/ignore-duration.js
@@ -11,7 +11,7 @@ export default Controller.extend(ModalFunctionality, {
       if (!this.ignoredUntil) {
         this.flash(
-          "alert-error"
+          "error"
         return;
GitHub sha: a8c63ddb541bfc534c919b8a7ea6be85988d568c
This commit appears in #14848 which was approved by CvX. It was merged by jbrw.
