FIX: call method only if it exists
discourse-objects creating empty Discourse object in window. It fails the _registerPluginCode method call since it is not exist.
diff --git a/app/models/theme_field.rb b/app/models/theme_field.rb
index 07e6e3f..a2d4af4 100644
--- a/app/models/theme_field.rb
+++ b/app/models/theme_field.rb
@@ -63,7 +63,7 @@ class ThemeField < ActiveRecord::Base
   def transpile(es6_source, version)
     template = Tilt::ES6ModuleTranspilerTemplate.new {}
     wrapped = <<PLUGIN_API_JS
-if ('Discourse' in window) {
+if ('Discourse' in window && typeof Discourse._registerPluginCode === 'function') {
 Discourse._registerPluginCode('#{version}', api => {
   #{settings(es6_source)}
   #{es6_source}
diff --git a/spec/models/theme_spec.rb b/spec/models/theme_spec.rb
index 26c706b..ed8bca1 100644
--- a/spec/models/theme_spec.rb
+++ b/spec/models/theme_spec.rb
@@ -326,7 +326,7 @@ HTML
       theme.save!
       transpiled = <<~HTML
-      if ('Discourse' in window) {
+      if ('Discourse' in window && typeof Discourse._registerPluginCode === 'function') {
         Discourse._registerPluginCode('1.0', function (api) {
           var settings = { "name": "bob" };
           alert(settings.name);var a = function a() {};
@@ -342,7 +342,7 @@ HTML
       setting.value = 'bill'
           var settings = { "name": "bill" };
GitHub sha: 59e5af46
