FIX: Capture CC addresses for forwarded emails (#14254)
When forwarding emails into the group inbox, we now use the original sender email as the from_address since 2ac9fd9dff5a2a9210e2b1b765e1a324bbb4f421. However, we have not been saving the original CC addresses of the forwarded email, which are needed to include those recipients in on the conversation when replying via the group inbox.
This commit captures the CC addresses on the incoming email, and makes sure the emails are created as staged users and added to the list of topic allowed users so they are included on CC’s sent by the GroupSmtpEmail and other jobs.
diff --git a/lib/email/receiver.rb b/lib/email/receiver.rb
index 2a0ce19..2b2cd36 100644
--- a/lib/email/receiver.rb
+++ b/lib/email/receiver.rb
@@ -143,13 +143,17 @@ module Email
     def create_incoming_email
+      cc_addresses = Array.wrap(@mail.cc)
+      if has_been_forwarded? && embedded_email&.cc
+        cc_addresses.concat(embedded_email.cc)
+      end
       IncomingEmail.create(
         message_id: @message_id,
         raw: Email::Cleaner.new(@raw_email).execute,
         subject: subject,
         from_address: @from_email,
         to_addresses: @mail.to,
-        cc_addresses: @mail.cc,
+        cc_addresses: cc_addresses,
         imap_uid_validity: @opts[:imap_uid_validity],
         imap_uid: @opts[:imap_uid],
         imap_group_id: @opts[:imap_group_id],
@@ -956,7 +960,7 @@ module Email
       email, display_name = parse_from_field(embedded)
       if forwarded_by_address && forwarded_by_name
-        forwarded_by_user = stage_sender_user(forwarded_by_address, forwarded_by_name)
+        @forwarded_by_user = stage_sender_user(forwarded_by_address, forwarded_by_name)
       return false if email.blank? || !email["@"]
@@ -985,10 +989,10 @@ module Email
                        post_type: post_type,
                        skip_validations: user.staged?)
         else
-          if forwarded_by_user
-            post.topic.topic_allowed_users.find_or_create_by!(user_id: forwarded_by_user.id)
+          if @forwarded_by_user
+            post.topic.topic_allowed_users.find_or_create_by!(user_id: @forwarded_by_user.id)
-          post.topic.add_small_action(forwarded_by_user || user, "forwarded")
+          post.topic.add_small_action(@forwarded_by_user || user, "forwarded")
@@ -1324,7 +1328,11 @@ module Email
       if result.post
         @incoming_email.update_columns(topic_id: result.post.topic_id, post_id: result.post.id)
         if result.post.topic&.private_message? && !is_bounce?
-          add_other_addresses(result.post, user)
+          add_other_addresses(result.post, user, @mail)
+            add_other_addresses(result.post, @forwarded_by_user || user, embedded_email)
+          end
         # Alert the people involved in the topic now that the incoming email
@@ -1346,11 +1354,11 @@ module Email
       html
-    def add_other_addresses(post, sender)
+    def add_other_addresses(post, sender, mail_object)
       %i(to cc bcc).each do |d|
-        next if @mail[d].blank?
+        next if mail_object[d].blank?
-        @mail[d].each do |address_field|
+        mail_object[d].each do |address_field|
           begin
             address_field.decoded
             email = address_field.address.downcase
diff --git a/spec/components/email/receiver_spec.rb b/spec/components/email/receiver_spec.rb
index e8be9d1..3f6e103 100644
--- a/spec/components/email/receiver_spec.rb
+++ b/spec/components/email/receiver_spec.rb
@@ -1064,13 +1064,40 @@ describe Email::Receiver do
         it "does not say the email was forwarded by the original sender, it says the email is forwarded by the group" do
-          expect { process(:forwarded_by_group_to_inbox) }.to change { User.where(staged: true).count }.by(2)
+          expect { process(:forwarded_by_group_to_inbox) }.to change { User.where(staged: true).count }.by(4)
           topic = Topic.last
           forwarded_small_post = topic.ordered_posts.last
           expect(forwarded_small_post.action_code).to eq("forwarded")
           expect(forwarded_small_post.user).to eq(User.find_by_email("team@somesmtpaddress.com"))
+        it "keeps track of the cc addresses of the forwarded email and creates staged users for them" do
+          topic = Topic.last
+          cc_user1 = User.find_by_email("terry@ccland.com")
+          cc_user2 = User.find_by_email("don@ccland.com")
+          fred_user = User.find_by_email("fred@bedrock.com")
+          team_user = User.find_by_email("team@somesmtpaddress.com")
+          expect(topic.incoming_email.first.cc_addresses).to eq("terry@ccland.com;don@ccland.com")
+          expect(topic.topic_allowed_users.pluck(:user_id)).to match_array([
+            fred_user.id, team_user.id, cc_user1.id, cc_user2.id
+        end
+        it "keeps track of the cc addresses of the final forwarded email as well" do
+          expect { process(:forwarded_by_group_to_inbox_double_cc) }.to change { User.where(staged: true).count }.by(5)
+          someother_user = User.find_by_email("someotherparty@test.com")
+          expect(topic.incoming_email.first.cc_addresses).to eq("someotherparty@test.com;terry@ccland.com;don@ccland.com")
+            fred_user.id, team_user.id, someother_user.id, cc_user1.id, cc_user2.id
+        end
         context "when staged user for the team email already exists" do
           let!(:staged_team_user) do
             User.create!(
@@ -1082,7 +1109,7 @@ describe Email::Receiver do
           it "uses that and does not create another staged user" do
-            expect { process(:forwarded_by_group_to_inbox) }.to change { User.where(staged: true).count }.by(1)
+            expect { process(:forwarded_by_group_to_inbox) }.to change { User.where(staged: true).count }.by(3)
             topic = Topic.last
diff --git a/spec/fixtures/emails/forwarded_by_group_to_inbox.eml b/spec/fixtures/emails/forwarded_by_group_to_inbox.eml
index fe170e5..c20a1dc 100644
--- a/spec/fixtures/emails/forwarded_by_group_to_inbox.eml
+++ b/spec/fixtures/emails/forwarded_by_group_to_inbox.eml
@@ -17,6 +17,7 @@ From: Fred Flintstone <fred@bedrock.com>
 Date: Mon, 1 Dec 2016 13:37:42 +0100
 Subject: Re: Login problems
 To: Discourse Team <team@somesmtpaddress.com>
+CC: Terry Jones <terry@ccland.com>, don@ccland.com
 Hello I am having some issues with my forum.
diff --git a/spec/fixtures/emails/forwarded_by_group_to_inbox_double_cc.eml b/spec/fixtures/emails/forwarded_by_group_to_inbox_double_cc.eml
new file mode 100644
index 0000000..1b4f855
--- /dev/null
+++ b/spec/fixtures/emails/forwarded_by_group_to_inbox_double_cc.eml
@@ -0,0 +1,36 @@
+Message-ID: <58@somesmtpaddress.mail>
+From: Discourse Team <team@somesmtpaddress.com>
+To: support+team@bar.com
+CC: someotherparty@test.com
+Date: Mon, 1 Dec 2016 13:37:42 +0100
+Subject: Fwd: Login problems
+Content-Type: multipart/related; boundary="00000000000072702105c89858de"
+--00000000000072702105c89858de
+Content-Type: multipart/alternative; boundary="00000000000072702005c89858dd"
+--00000000000072702005c89858dd
+Content-Type: text/plain; charset="UTF-8"
+Content-Transfer-Encoding: quoted-printable
+---------- Forwarded message ---------
+From: Fred Flintstone <fred@bedrock.com>
+Subject: Re: Login problems
+To: Discourse Team <team@somesmtpaddress.com>
+Hello I am having some issues with my forum.
+Fred
+Content-Type: text/html; charset="UTF-8"
+<p>Hello I am having some issues with my forum.</p>
+<br>Fred<br>
+--00000000000072702005c89858dd--
GitHub sha: 9f36d8ad433aaa0eec051b49938fff7d3d8e06b6
This commit appears in #14254 which was approved by SamSaffron. It was merged by martin.
