FIX: category id wasn't stored when enqueueing a topic
FIX: category id wasn’t stored when enqueueing a topic
diff --git a/lib/new_post_manager.rb b/lib/new_post_manager.rb
index 92baa71..c99abea 100644
--- a/lib/new_post_manager.rb
+++ b/lib/new_post_manager.rb
@@ -188,6 +188,7 @@ class NewPostManager
       reviewable_by_moderator: true
     reviewable.payload['title'] = @args[:title] if @args[:title].present?
+    reviewable.category_id = args[:category] if args[:category].present?
     create_options = reviewable.create_options
diff --git a/spec/components/new_post_manager_spec.rb b/spec/components/new_post_manager_spec.rb
index c1a3efc..bc35f00 100644
--- a/spec/components/new_post_manager_spec.rb
+++ b/spec/components/new_post_manager_spec.rb
@@ -133,6 +133,27 @@ describe NewPostManager do
+    context "with uncategorized disabled, and approval" do
+      before do
+        SiteSetting.allow_uncategorized_topics = false
+        SiteSetting.approve_unless_trust_level = 4
+      end
+      it "will return an enqueue result" do
+        npm = NewPostManager.new(
+          Fabricate(:user),
+          title: 'this is a new topic title',
+          raw: "this is the raw content",
+          category: Fabricate(:category).id
+        result = NewPostManager.default_handler(npm)
+        expect(NewPostManager.queue_enabled?).to eq(true)
+        expect(result.action).to eq(:enqueued)
+        expect(result.errors).to be_blank
+      end
+    end
     context 'with staged moderation setting enabled' do
       before do
         SiteSetting.approve_unless_staged = true
GitHub sha: 123c05cb
