FIX: Clarify revert text (PR #8162)
When you open the revision history of a post a button is shown on the bottom right labelled “Revert to this revision”. It is shown under the later revision on the right, but it actually refers to the older revision on the left.
It might be less confusing if it were renamed.
GitHub
Thanks for contributing this pull request! Could you please sign our CLA so we can review it? http://www.discourse.org/cla
Hmm no we have other plans here, such as putting the revision number on the button per discussion on meta.
— You are receiving this because you are subscribed to this thread. Reply to this email directly, view it on GitHub https://github.com/discourse/discourse/pull/8162?email_source=notifications&email_token=AALTWVKSROTSGPDZEZNZIPLQND3ELA5CNFSM4I5ZHSV2YY3PNVWWK3TUL52HS4DFVREXG43VMVBW63LNMVXHJKTDN5WW2ZLOORPWSZGOEAN3INI#issuecomment-538686517, or mute the thread https://github.com/notifications/unsubscribe-auth/AALTWVLEQH5FQZSGS3AMQQTQND3ELANCNFSM4I5ZHSVQ .
sorry, closing this per @coding-horror
