FIX: Cleanup DiscoursePluginRegistry state after tests that use it
This was causing some heisentests
diff --git a/spec/components/stylesheet/compiler_spec.rb b/spec/components/stylesheet/compiler_spec.rb
index 7443fbf..5191d72 100644
--- a/spec/components/stylesheet/compiler_spec.rb
+++ b/spec/components/stylesheet/compiler_spec.rb
@@ -40,6 +40,7 @@ describe Stylesheet::Compiler do
       after do
         Discourse.plugins.pop
         Stylesheet::Importer.register_imports!
+        DiscoursePluginRegistry.reset!
       it "does not include theme variables in plugins" do
diff --git a/spec/components/stylesheet/manager_spec.rb b/spec/components/stylesheet/manager_spec.rb
index e7054f3..95ca08b 100644
--- a/spec/components/stylesheet/manager_spec.rb
+++ b/spec/components/stylesheet/manager_spec.rb
@@ -68,7 +68,7 @@ describe Stylesheet::Manager do
   describe 'digest' do
     after do
-      DiscoursePluginRegistry.stylesheets.delete "fake_file"
     it 'can correctly account for plugins in digest' do
diff --git a/spec/lib/content_security_policy_spec.rb b/spec/lib/content_security_policy_spec.rb
index df0b66a..276dcb0 100644
--- a/spec/lib/content_security_policy_spec.rb
+++ b/spec/lib/content_security_policy_spec.rb
@@ -4,6 +4,10 @@ require 'rails_helper'
 describe ContentSecurityPolicy do
   before { ContentSecurityPolicy.base_url = nil }
+  after do
+  end
   describe 'report-uri' do
     it 'is enabled by SiteSetting' do
       SiteSetting.content_security_policy_collect_reports = true
GitHub sha: 7f8cdea9
