FIX: Correct site setting name (#14686)
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index 6f060d4..ae51ce9 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -1548,7 +1548,7 @@ en:
     summary_max_results: "Maximum posts returned by 'Summarize This Topic'"
     summary_timeline_button: "Show a 'Summarize' button in the timeline"
-    enable_personal_messages: "Allow trust level 1 (configurable via min trust level to send messages) users to create messages and reply to messages. Note that staff can always send messages no matter what."
+    enable_personal_messages: "Allow trust level 1 (configurable via min trust to send messages) users to create messages and reply to messages. Note that staff can always send messages no matter what."
     enable_system_message_replies: "Allows users to reply to system messages, even if personal messages are disabled"
     enable_long_polling: "Message bus used for notification can use long polling"
     enable_chunked_encoding: "Enable chunked encoding responses by the server. This feature works on most setups however some proxies may buffer, causing responses to be delayed"
GitHub sha: 61a7fbdd9e2fe21e70058fd6a5b1a71a969af7e0
This commit appears in #14686 which was approved by pmusaraj. It was merged by jomaxro.
