FIX: Correct the misalignment of popover arrows (PR #9947)
  • Fixes position of the top arrow, and border width of both
  • Merged top and transform properties
  • .5px values are required to make arrow border appear the same with as overall popover border width
Before/after
Screen Shot 2020-05-25 at 14 59 50 Screen Shot 2020-05-25 at 15 01 27
GitHub
:clap::eye:
I’m curious if it works in non retina display ?
@jjaffeux I did have a chance to try it out on a Windows machine with a non-high DPI display and there were no issues. And I just re-tested it with Firefox on macOS using the “Open in Low Resolution” option and it looked more or less ok (bearing in mind that it the whole app is then a blurry mess, and that using custom zoom levels causes the arrow to break slightly, but that was also the case on Firefox before this change)
great :ok_hand: then please merge it before beta
