FIX: Correct version comparison logic when comparing stable to beta (PR #10135)
For example, version 1.3.0 should be considered higher than 1.3.0.beta3. So Discourse.has_needed_version?('1.3.0', '1.3.0.beta3') should return true
GitHub
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
https://meta.discourse.org/t/user-card-directory/144479/41
Can we replace all this custom logic with just Gem::Version?
Gem::Version.new('1.3.0') > Gem::Version.new('1.3.0.beta3')
=> true
:joy: well yes, I guess we can! I assumed that we had a custom implementation because our .beta# syntax was a little weird.But it looks like Gem::Version works just fine.
Updated the PR
do we need to backport this?
