FIX: correctly retrieve 'login required' setting value on wizard (#7355)
FIX: correctly retrieve ‘login required’ setting value on wizard (#7355)
  • FIX: correctly retrieve ‘login required’ setting value on wizard
FEATURE: extract ‘invite only’ setting in a separate checkbox control
  • Update invite_only checkbox locale on wizard.
Co-Authored-By: techAPJ arpit@techapj.com
diff --git a/app/assets/javascripts/wizard/templates/components/wizard-field-checkbox.hbs b/app/assets/javascripts/wizard/templates/components/wizard-field-checkbox.hbs
new file mode 100644
index 0000000..d520465
--- /dev/null
+++ b/app/assets/javascripts/wizard/templates/components/wizard-field-checkbox.hbs
@@ -0,0 +1,7 @@
+<label>
+{{input type="checkbox"
+        class="wizard-checkbox"
+        checked=field.value}}
+{{field.placeholder}}
+</label>
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index 2a1b0e5..f156782 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -4261,10 +4261,12 @@ en:
             choices:
               open:
                 label: "Public"
-                description: "Anyone can access this community and sign up for an account"
+                description: "Anyone can access this community"
               restricted:
                 label: "Private"
-                description: "Only people I have invited or approved can access this community"
+                description: "Only logged in users can access this community"
+          invite_only:
+              placeholder: "People must be explicitly invited. Public registration is disabled."
       contact:
         title: "Contact"
diff --git a/lib/wizard/builder.rb b/lib/wizard/builder.rb
index d5df149..b0abb21 100644
--- a/lib/wizard/builder.rb
+++ b/lib/wizard/builder.rb
@@ -76,17 +76,22 @@ class Wizard
       @wizard.append_step('privacy') do |step|
-        locked = SiteSetting.login_required? && SiteSetting.invite_only?
         privacy = step.add_field(id: 'privacy',
                                  type: 'radio',
                                  required: true,
-                                 value: locked ? 'restricted' : 'open')
+                                 value: SiteSetting.login_required? ? 'restricted' : 'open')
         privacy.add_choice('open', icon: 'unlock')
         privacy.add_choice('restricted', icon: 'lock')
+        invite_only = step.add_field(id: 'invite_only',
+                                     type: 'checkbox',
+                                     required: false,
+                                     placeholder: 'wizard.invites.add_user',
+                                     value: SiteSetting.invite_only?)
         step.on_update do |updater|
           updater.update_setting(:login_required, updater.fields[:privacy] == 'restricted')
-          updater.update_setting(:invite_only, updater.fields[:privacy] == 'restricted')
+          updater.update_setting(:invite_only, updater.fields[:invite_only])
diff --git a/spec/components/wizard/step_updater_spec.rb b/spec/components/wizard/step_updater_spec.rb
index dd6adfc..a79f34d 100644
--- a/spec/components/wizard/step_updater_spec.rb
+++ b/spec/components/wizard/step_updater_spec.rb
@@ -63,7 +63,7 @@ describe Wizard::StepUpdater do
   context "privacy settings" do
     it "updates to open correctly" do
-      updater = wizard.create_updater('privacy', privacy: 'open')
+      updater = wizard.create_updater('privacy', privacy: 'open', invite_only: false)
       updater.update
       expect(updater.success?).to eq(true)
       expect(SiteSetting.login_required?).to eq(false)
@@ -72,7 +72,7 @@ describe Wizard::StepUpdater do
     it "updates to private correctly" do
-      updater = wizard.create_updater('privacy', privacy: 'restricted')
+      updater = wizard.create_updater('privacy', privacy: 'restricted', invite_only: true)
       updater.update
       expect(SiteSetting.login_required?).to eq(true)
diff --git a/spec/components/wizard/wizard_builder_spec.rb b/spec/components/wizard/wizard_builder_spec.rb
index bcdf257..a9c671e 100644
--- a/spec/components/wizard/wizard_builder_spec.rb
+++ b/spec/components/wizard/wizard_builder_spec.rb
@@ -113,4 +113,22 @@ describe Wizard::Builder do
+  context 'privacy step' do
+    let(:privacy_step) { wizard.steps.find { |s| s.id == 'privacy' } }
+    it 'should set the right default value for the fields' do
+      SiteSetting.login_required = true
+      SiteSetting.invite_only = false
+      fields = privacy_step.fields
+      login_required_field = fields.first
+      invite_only_field = fields.last
+      expect(login_required_field.id).to eq('privacy')
+      expect(login_required_field.value).to eq("restricted")
+      expect(invite_only_field.id).to eq('invite_only')
+      expect(invite_only_field.value).to eq(false)
+    end
+  end
GitHub sha: 7143572e
