FIX: correctly take category/group filters into csv export (#9300)
diff --git a/app/jobs/regular/export_csv_file.rb b/app/jobs/regular/export_csv_file.rb
index ee172de..39f9c56 100644
--- a/app/jobs/regular/export_csv_file.rb
+++ b/app/jobs/regular/export_csv_file.rb
@@ -7,6 +7,10 @@ module Jobs
   class ExportCsvFile < ::Jobs::Base
     sidekiq_options retry: false
+    attr_accessor :extra
+    attr_accessor :current_user
+    attr_accessor :entity
     HEADER_ATTRS_FOR ||= HashWithIndifferentAccess.new(
       user_archive: ['topic_title', 'categories', 'is_pm', 'post', 'like_count', 'reply_count', 'url', 'created_at'],
       user_list: ['id', 'name', 'username', 'email', 'title', 'created_at', 'last_seen_at', 'last_posted_at', 'last_emailed_at', 'trust_level', 'approved', 'suspended_at', 'suspended_till', 'silenced_till', 'active', 'admin', 'moderator', 'ip_address', 'staged', 'secondary_emails'],
@@ -180,8 +184,13 @@ module Jobs
       @extra[:start_date] = @extra[:start_date].to_date.beginning_of_day if @extra[:start_date].is_a?(String)
       @extra[:end_date] = @extra[:end_date].to_date.end_of_day if @extra[:end_date].is_a?(String)
-      @extra[:category_id] = @extra[:category_id].present? ? @extra[:category_id].to_i : nil
-      @extra[:group_id] = @extra[:group_id].present? ? @extra[:group_id].to_i : nil
+      @extra[:filters] = {}
+      if @extra[:category_id].present?
+        @extra[:filters][:category] = @extra[:category_id].to_i
+      end
+      if @extra[:group_id].present?
+        @extra[:filters][:group] = @extra[:group_id].to_i
+      end
       report = Report.find(@extra[:name], @extra)
diff --git a/spec/jobs/export_csv_file_spec.rb b/spec/jobs/export_csv_file_spec.rb
index 3852494..62ffb15 100644
--- a/spec/jobs/export_csv_file_spec.rb
+++ b/spec/jobs/export_csv_file_spec.rb
@@ -55,7 +55,7 @@ describe Jobs::ExportCsvFile do
       post = Fabricate(:post, topic: topic, user: user)
       exporter = Jobs::ExportCsvFile.new
-      exporter.instance_variable_set(:@current_user, User.find_by(id: user.id))
+      exporter.current_user = User.find_by(id: user.id)
       rows = []
       exporter.user_archive_export { |row| rows << row }
@@ -79,9 +79,9 @@ describe Jobs::ExportCsvFile do
     let(:exporter) do
-      exporter.instance_variable_set(:@entity, 'report')
-      exporter.instance_variable_set(:@extra, HashWithIndifferentAccess.new(start_date: '2010-01-01', end_date: '2011-01-01'))
+      exporter.entity = 'report'
+      exporter.extra = HashWithIndifferentAccess.new(start_date: '2010-01-01', end_date: '2011-01-01')
       exporter
@@ -89,7 +89,7 @@ describe Jobs::ExportCsvFile do
       user.user_visits.create!(visited_at: '2010-01-01', posts_read: 42)
       Fabricate(:user).user_visits.create!(visited_at: '2010-01-03', posts_read: 420)
-      exporter.instance_variable_get(:@extra)['name'] = 'dau_by_mau'
+      exporter.extra['name'] = 'dau_by_mau'
       report = exporter.report_export.to_a
       expect(report.first).to contain_exactly("Day", "Percent")
@@ -97,11 +97,28 @@ describe Jobs::ExportCsvFile do
       expect(report.third).to contain_exactly("2010-01-03", "50.0")
+    it 'works with filters' do
+      user.user_visits.create!(visited_at: '2010-01-01', posts_read: 42)
+      group = Fabricate(:group)
+      user1 = Fabricate(:user)
+      group_user = Fabricate(:group_user, group: group, user: user1)
+      user1.user_visits.create!(visited_at: '2010-01-03', posts_read: 420)
+      exporter.extra['name'] = 'visits'
+      exporter.extra['group_id'] = group.id
+      report = exporter.report_export.to_a
+      expect(report.length).to eq(2)
+      expect(report.first).to contain_exactly("Day", "Count")
+      expect(report.second).to contain_exactly("2010-01-03", "1")
+    end
     it 'works with single-column reports with default label' do
       user.user_visits.create!(visited_at: '2010-01-01')
       Fabricate(:user).user_visits.create!(visited_at: '2010-01-03')
-      exporter.instance_variable_get(:@extra)['name'] = 'visits'
@@ -113,7 +130,7 @@ describe Jobs::ExportCsvFile do
       DiscourseIpInfo.stubs(:get).with("1.1.1.1").returns(location: "Earth")
       user.user_auth_token_logs.create!(action: "login", client_ip: "1.1.1.1", created_at: '2010-01-01')
-      exporter.instance_variable_get(:@extra)['name'] = 'staff_logins'
+      exporter.extra['name'] = 'staff_logins'
       expect(report.first).to contain_exactly("User", "Location", "Login at")
@@ -133,7 +150,7 @@ describe Jobs::ExportCsvFile do
       ApplicationRequest.create!(date: '2010-01-02', req_type: 'page_view_crawler', count: 8)
       ApplicationRequest.create!(date: '2010-01-03', req_type: 'page_view_crawler', count: 9)
-      exporter.instance_variable_get(:@extra)['name'] = 'consolidated_page_views'
+      exporter.extra['name'] = 'consolidated_page_views'
       expect(report[0]).to contain_exactly("Day", "Logged in users", "Anonymous users", "Crawlers")
GitHub sha: aeaea3c1
This commit appears in #9300 which was approved by eviltrout. It was merged by jjaffeux.
