FIX: custom SQL with a trailing comment might break BadgeGranter SQL (PR #9285)
For example given a custom badge with SQL:
SELECT 1
-- I am a comment
You end up with
FROM (SELECT 1
-- I am a comment) q
This fix adds newlines so you end up with the now-valid:
FROM (
  SELECT 1
-- I am a comment
) q
GitHub
Can we add a test to this one?
@Supermathie, there are other lines with similar problems in the same file, discourse/badge_granter.rb at 7180fcd39f20ca2a77ed33d4b09960193033e97c · discourse/discourse · GitHub for example.
