FIX: disabled option for sk was not working correctly (#10900)
Name was incorrect and it was only removing cursor events and not changing style.
diff --git a/app/assets/javascripts/select-kit/addon/components/select-kit.js b/app/assets/javascripts/select-kit/addon/components/select-kit.js
index 8931ad6..a89055b 100644
--- a/app/assets/javascripts/select-kit/addon/components/select-kit.js
+++ b/app/assets/javascripts/select-kit/addon/components/select-kit.js
@@ -42,7 +42,7 @@ export default Component.extend(
     classNameBindings: [
       "selectKit.isLoading:is-loading",
       "selectKit.isExpanded:is-expanded",
-      "selectKit.isDisabled:is-disabled",
+      "selectKit.options.disabled:is-disabled",
       "selectKit.isHidden:is-hidden",
       "selectKit.hasSelection:has-selection",
@@ -178,8 +178,6 @@ export default Component.extend(
     didUpdateAttrs() {
       this._super(...arguments);
-      this.set("selectKit.isDisabled", this.isDisabled || false);
       this.handleDeprecations();
@@ -985,7 +983,7 @@ export default Component.extend(
         allowUncategorized: "options.allowUncategorized",
         none: "options.none",
         rootNone: "options.none",
-        isDisabled: "options.isDisabled",
+        disabled: "options.disabled",
         rootNoneLabel: "options.none",
         showFullTitle: "options.showFullTitle",
         title: "options.translatedNone",
diff --git a/app/assets/stylesheets/common/select-kit/single-select.scss b/app/assets/stylesheets/common/select-kit/single-select.scss
index 8692177..edb1274 100644
--- a/app/assets/stylesheets/common/select-kit/single-select.scss
+++ b/app/assets/stylesheets/common/select-kit/single-select.scss
@@ -14,4 +14,10 @@
       border-color: var(--tertiary);
+  &.is-disabled {
+    .select-kit-header {
+      opacity: 0.5;
GitHub sha: a73fd422
This commit appears in #10900 which was approved by CvX. It was merged by jjaffeux.
