FIX: Disallow email invites if enable_local_logins is disabled (PR #10805)
allowEmails used to always be set to true and did not use can_invite_via_email, which checks for enable_local_logins.
GitHub
Why is this step required? Are you using parse(stringify) to do some sort of deep clone?
Yes, that is the use case.
