Fix disk detection units
df was reporting bytes while du was reporting Kilobytes.
diff --git a/templates/postgres.template.yml b/templates/postgres.template.yml
index 6731da0..0528256 100644
--- a/templates/postgres.template.yml
+++ b/templates/postgres.template.yml
@@ -62,8 +62,8 @@ run:
        if [ ! "12" = "$PG_MAJOR_OLD" ]; then
          echo Upgrading PostgreSQL from version ${PG_MAJOR_OLD} to 12
-         free_disk=$(df /shared | tail -n 1 | awk '{print $4}')
-         required=$(($(du -s /shared/postgres_data | awk '{print $1}') * 2))
+         free_disk=$(df -P /shared | tail -n 1 | awk '{print $4}')
+         required=$(($(du -sb /shared/postgres_data | awk '{print $1}') * 2))
          if [ "$free_disk" -lt "$required" ]; then
           echo "WARNING: Upgrading PostgresSQL would require an addtional $(numfmt --to=si $(($required - $free_disk))) of disk space"
GitHub sha: 882358d5
