FIX: Do not change tracked categories for staged users (#10076)
diff --git a/app/controllers/admin/site_settings_controller.rb b/app/controllers/admin/site_settings_controller.rb
index 4d662f7..c143e04 100644
--- a/app/controllers/admin/site_settings_controller.rb
+++ b/app/controllers/admin/site_settings_controller.rb
@@ -61,7 +61,7 @@ class Admin::SiteSettingsController < Admin::AdminController
         (new_category_ids - previous_category_ids).each do |category_id|
           skip_user_ids = CategoryUser.where(category_id: category_id).pluck(:user_id)
-          User.where.not(id: skip_user_ids).select(:id).find_in_batches do |users|
+          User.real.where(staged: false).where.not(id: skip_user_ids).select(:id).find_in_batches do |users|
             category_users = []
             users.each { |user| category_users << { category_id: category_id, user_id: user.id, notification_level: notification_level } }
             CategoryUser.insert_all!(category_users)
@@ -88,7 +88,7 @@ class Admin::SiteSettingsController < Admin::AdminController
         (new_tag_ids - previous_tag_ids).each do |tag_id|
           skip_user_ids = TagUser.where(tag_id: tag_id).pluck(:user_id)
             tag_users = []
             users.each { |user| tag_users << { tag_id: tag_id, user_id: user.id, notification_level: notification_level, created_at: now, updated_at: now } }
             TagUser.insert_all!(tag_users)
@@ -135,8 +135,10 @@ class Admin::SiteSettingsController < Admin::AdminController
       user_ids = CategoryUser.where(category_id: previous_category_ids - new_category_ids, notification_level: notification_level).distinct.pluck(:user_id)
       user_ids += User
+        .real
         .joins("CROSS JOIN categories c")
         .joins("LEFT JOIN category_users cu ON users.id = cu.user_id AND c.id = cu.category_id")
+        .where(staged: false)
         .where("c.id IN (?) AND cu.notification_level IS NULL", new_category_ids - previous_category_ids)
         .distinct
         .pluck("users.id")
@@ -159,8 +161,10 @@ class Admin::SiteSettingsController < Admin::AdminController
       user_ids = TagUser.where(tag_id: previous_tag_ids - new_tag_ids, notification_level: notification_level).distinct.pluck(:user_id)
       user_ids += User
+        .real
         .joins("CROSS JOIN tags t")
         .joins("LEFT JOIN tag_users tu ON users.id = tu.user_id AND t.id = tu.tag_id")
         .where("t.id IN (?) AND tu.notification_level IS NULL", new_tag_ids - previous_tag_ids)
         .distinct
         .pluck("users.id")
diff --git a/spec/requests/admin/site_settings_controller_spec.rb b/spec/requests/admin/site_settings_controller_spec.rb
index 7962ab2..1b74fb9 100644
--- a/spec/requests/admin/site_settings_controller_spec.rb
+++ b/spec/requests/admin/site_settings_controller_spec.rb
@@ -97,8 +97,9 @@ describe Admin::SiteSettingsController do
       describe 'default categories' do
-        let(:user1) { Fabricate(:user) }
-        let(:user2) { Fabricate(:user) }
+        fab!(:user1) { Fabricate(:user) }
+        fab!(:user2) { Fabricate(:user) }
+        fab!(:staged_user) { Fabricate(:staged) }
         let(:watching) { NotificationLevels.all[:watching] }
         let(:tracking) { NotificationLevels.all[:tracking] }
@@ -120,7 +121,7 @@ describe Admin::SiteSettingsController do
           expect(CategoryUser.where(category_id: category_ids.first, notification_level: watching).count).to eq(0)
-          expect(CategoryUser.where(category_id: category_ids.last, notification_level: watching).count).to eq(User.count - 1)
+          expect(CategoryUser.where(category_id: category_ids.last, notification_level: watching).count).to eq(User.real.where(staged: false).count - 1)
         it 'should not update existing users user preference' do
@@ -135,8 +136,9 @@ describe Admin::SiteSettingsController do
       describe 'default tags' do
@@ -158,7 +160,7 @@ describe Admin::SiteSettingsController do
           expect(TagUser.where(tag_id: tags.first.id, notification_level: watching).count).to eq(0)
-          expect(TagUser.where(tag_id: tags.last.id, notification_level: watching).count).to eq(User.count - 1)
+          expect(TagUser.where(tag_id: tags.last.id, notification_level: watching).count).to eq(User.real.where(staged: false).count - 1)
@@ -173,7 +175,8 @@ describe Admin::SiteSettingsController do
       describe '#user_count' do
-        let(:user) { Fabricate(:user) }
+        fab!(:user) { Fabricate(:user) }
         it 'should return correct user count for default categories change' do
@@ -183,7 +186,7 @@ describe Admin::SiteSettingsController do
             default_categories_watching: category_id
-          expect(response.parsed_body["user_count"]).to eq(User.count)
+          expect(response.parsed_body["user_count"]).to eq(User.real.where(staged: false).count)
           CategoryUser.create!(category_id: category_id, notification_level: tracking, user: user)
@@ -191,7 +194,7 @@ describe Admin::SiteSettingsController do
-          expect(response.parsed_body["user_count"]).to eq(User.count - 1)
+          expect(response.parsed_body["user_count"]).to eq(User.real.where(staged: false).count - 1)
           SiteSetting.setting(:default_categories_watching, "")
@@ -203,7 +206,7 @@ describe Admin::SiteSettingsController do
             default_tags_watching: tag.name
           TagUser.create!(tag_id: tag.id, notification_level: tracking, user: user)
@@ -211,7 +214,7 @@ describe Admin::SiteSettingsController do
           SiteSetting.setting(:default_tags_watching, "")
GitHub sha: a1df68d4
This commit appears in #10076 which was approved by ZogStriP. It was merged by nbianca.
