FIX: Do not download emojis in pull_hotlinked_images
diff --git a/app/jobs/regular/pull_hotlinked_images.rb b/app/jobs/regular/pull_hotlinked_images.rb
index 672b85a..23f6934 100644
--- a/app/jobs/regular/pull_hotlinked_images.rb
+++ b/app/jobs/regular/pull_hotlinked_images.rb
@@ -156,7 +156,10 @@ module Jobs
       # If file is on the forum or CDN domain
       if Discourse.store.has_been_uploaded?(src) || src =~ /\A\/[^\/]/i
-        # Return true if we can't find the upload in the db
+        return false if src =~ /\/images\/emoji\//
+        # Someone could hotlink a file from a different site on the same CDN,
+        # so check whether we have it in this database
         return !Upload.get_from_url(src)
diff --git a/spec/jobs/pull_hotlinked_images_spec.rb b/spec/jobs/pull_hotlinked_images_spec.rb
index 962699f..446adea 100644
--- a/spec/jobs/pull_hotlinked_images_spec.rb
+++ b/spec/jobs/pull_hotlinked_images_spec.rb
@@ -191,6 +191,11 @@ describe Jobs::PullHotlinkedImages do
         expect(subject.should_download_image?(src)).to eq(true)
+      it "returns false for emoji" do
+        src = Emoji.url_for("testemoji.png")
+        expect(subject.should_download_image?(src)).to eq(false)
+      end
       it 'returns false for valid remote URLs' do
         expect(subject.should_download_image?("http://meta.discourse.org")).to eq(false)
GitHub sha: 54afa314
I think we’ll need to check against the host/cdn as well. The regexp here is too generic such that a possible URL like http://some.other.site/maybe/images/emoji/test.png will not be pulled.
This all happens inside the conditional Discourse.store.has_been_uploaded?(src), which checks the file is on the CDN, or on the host.
Could it potentially return false and match on src =~ /\A\/[^\/]/i? Just thinking out loud.
src =~ /\A\/[^\/]/i translates to “a URL starting with a single forward-slash”. So that shouldn’t match any URLs that point to a different host.
O good point xD I guess I should go to bed now
