FIX: Do not highlight large code blocks (#10125)
diff --git a/app/assets/javascripts/discourse/app/lib/highlight-syntax.js b/app/assets/javascripts/discourse/app/lib/highlight-syntax.js
index 48543dc..404e73c 100644
--- a/app/assets/javascripts/discourse/app/lib/highlight-syntax.js
+++ b/app/assets/javascripts/discourse/app/lib/highlight-syntax.js
@@ -14,6 +14,11 @@ export default function highlightSyntax($elem) {
   $(selector, $elem).each(function(i, e) {
+    // Large code blocks can cause crashes or slowdowns
+    if (e.innerHTML.length > 30000) {
+      return;
     $(e).removeClass("lang-auto");
     loadScript(path).then(() => {
       customHighlightJSLanguages();
diff --git a/test/javascripts/components/highlighted-code-test.js b/test/javascripts/components/highlighted-code-test.js
index 38b0f2d..27cfe56 100644
--- a/test/javascripts/components/highlighted-code-test.js
+++ b/test/javascripts/components/highlighted-code-test.js
@@ -1,5 +1,7 @@
 import componentTest from "helpers/component-test";
+const LONG_CODE_BLOCK = "puts a\n".repeat(15000);
 moduleForComponent("highlighted-code", { integration: true });
 componentTest("highlighting code", {
@@ -20,3 +22,22 @@ componentTest("highlighting code", {
+componentTest("large code blocks are not highlighted", {
+  template: "{{highlighted-code lang='ruby' code=code}}",
+  beforeEach() {
+    Discourse.HighlightJSPath =
+      "assets/highlightjs/highlight-test-bundle.min.js";
+    this.set("code", LONG_CODE_BLOCK);
+  async test(assert) {
+    assert.equal(
+      find("code")
+        .text()
+        .trim(),
+      LONG_CODE_BLOCK.trim()
GitHub sha: 4a904646
This commit appears in #10125 which was approved by ZogStriP. It was merged by nbianca.
