FIX: Do not raise exception if the authenticator email is missing
Followup to 296cdc53ee41bb58d0fe5c56df6fc1f7100dd7d4
diff --git a/lib/auth/result.rb b/lib/auth/result.rb
index d825758..0e715bd 100644
--- a/lib/auth/result.rb
+++ b/lib/auth/result.rb
@@ -19,7 +19,7 @@ class Auth::Result
   def email
-    @email.downcase
+    @email&.downcase
   def failed?
diff --git a/spec/components/auth/managed_authenticator_spec.rb b/spec/components/auth/managed_authenticator_spec.rb
index 84889de..ad1ac40 100644
--- a/spec/components/auth/managed_authenticator_spec.rb
+++ b/spec/components/auth/managed_authenticator_spec.rb
@@ -140,6 +140,17 @@ describe Auth::ManagedAuthenticator do
         result = authenticator.after_authenticate(hash)
         expect(result.user.id).to eq(user.id)
+      it 'works if there is no email' do
+        expect {
+          result = authenticator.after_authenticate(hash.deep_merge(info: { email: nil }))
+          expect(result.user).to eq(nil)
+          expect(result.username).to eq("IAmGroot")
+          expect(result.email).to eq(nil)
+        }.to change { UserAssociatedAccount.count }.by(1)
+        expect(UserAssociatedAccount.last.user).to eq(nil)
+        expect(UserAssociatedAccount.last.info["nickname"]).to eq("IAmGroot")
+      end
     describe "avatar on update" do
GitHub sha: 5755d388
