FIX: do not remove stop words when using English locale
PG already handles English stop words, the list in cppjieba is bigger than the list PG uses, which in turn causes confusion cause words such as “volume” are stripped using cppijieba stop word list
We will follow up with another commit here to apply the Chinese word stopwords, but for now to eliminate the confusion we are skipping applying the stopword list when the dictionary in PG is in English.
diff --git a/lib/search.rb b/lib/search.rb
index ffe0888..8d76057 100644
--- a/lib/search.rb
+++ b/lib/search.rb
@@ -72,7 +72,18 @@ class Search
         require 'cppjieba_rb' unless defined? CppjiebaRb
         mode = (purpose == :query ? :query : :mix)
         data = CppjiebaRb.segment(search_data, mode: mode)
-        data = CppjiebaRb.filter_stop_word(data).join(' ')
+        # TODO: we still want to tokenize here but the current stopword list is too wide
+        # in cppjieba leading to words such as volume to be skipped. PG already has an English
+        # stopword list so use that vs relying on cppjieba
+        if ts_config != 'english'
+          data = CppjiebaRb.filter_stop_word(data)
+        else
+          data = data.filter { |s| s.present? }
+        end
+        data = data.join(' ')
       else
         data.squish!
diff --git a/spec/lib/search_spec.rb b/spec/lib/search_spec.rb
index 7b81e27..f8c6fae 100644
--- a/spec/lib/search_spec.rb
+++ b/spec/lib/search_spec.rb
@@ -4,6 +4,20 @@ require 'rails_helper'
 describe Search do
+  context "#prepare_data" do
+    it "does not remove English stop words in mixed mode" do
+      SiteSetting.search_tokenize_chinese_japanese_korean = true
+      tokenized = Search.prepare_data("monkey 吃香蕉 in a loud volume")
+      expect(tokenized).to eq("monkey 吃 香蕉 in a loud volume")
+      SiteSetting.default_locale = 'zh_CN'
+      expect(tokenized).to eq("monkey 吃 香蕉 loud")
+    end
+  end
   context "#ts_config" do
     it "maps locales to correct Postgres dictionaries" do
       expect(Search.ts_config).to eq("english")
GitHub sha: 862773ec
