FIX: Do not show invalid option in flair chooser (#13725)
Both of the commits in this PR are meant to fix the problem of invalid option being shown in the flair chooser. An invalid option can be shown if at some point it was a valid one - a group with a flair that was later changed by an admin and flair was removed. The other option an invalid option can be selected is if the user had a primary group when the migration ran and copied the same value to the flair_group_id column.
  • FIX: Set flair_group_id only if group has flair
Follow up to 4ba93aac667f8e50ffb63635bb4e42ff34dcd58e.
  • FIX: Do not show invalid option in flair chooser
If selected flair group became unavailable because the flair was removed then the option would still be selected and visible as an ID only.
diff --git a/app/assets/javascripts/select-kit/addon/components/flair-chooser.js b/app/assets/javascripts/select-kit/addon/components/flair-chooser.js
index 96e912e..f8eabd0 100644
--- a/app/assets/javascripts/select-kit/addon/components/flair-chooser.js
+++ b/app/assets/javascripts/select-kit/addon/components/flair-chooser.js
@@ -1,3 +1,4 @@
+import { computed } from "@ember/object";
 import ComboBoxComponent from "select-kit/components/combo-box";
 export default ComboBoxComponent.extend({
@@ -11,4 +12,22 @@ export default ComboBoxComponent.extend({
   modifyComponentForRow() {
     return "flair-row";
+  selectedContent: computed(
+    "value",
+    "content.[]",
+    "selectKit.noneItem",
+    function () {
+      const content = (this.content || []).findBy(
+        this.selectKit.valueProperty,
+        this.value
+      if (content) {
+        return this.selectKit.modifySelection(content);
+      } else {
+        return this.selectKit.noneItem;
diff --git a/db/migrate/20210713092503_set_users_flair_group_id.rb b/db/migrate/20210713092503_set_users_flair_group_id.rb
index fdcd573..00ba41b 100644
--- a/db/migrate/20210713092503_set_users_flair_group_id.rb
+++ b/db/migrate/20210713092503_set_users_flair_group_id.rb
@@ -5,7 +5,10 @@ class SetUsersFlairGroupId < ActiveRecord::Migration[6.1]
     execute <<~SQL
       UPDATE users
       SET flair_group_id = primary_group_id
-      WHERE flair_group_id IS NULL
+      FROM groups
+      WHERE users.primary_group_id = groups.id AND
+            users.flair_group_id IS NULL AND
+            (groups.flair_icon IS NOT NULL OR groups.flair_upload_id IS NOT NULL)
     SQL
GitHub sha: 5bff65aa691ed9c112867b25770839d81de04bcb
This commit appears in #13725 which was approved by ZogStriP. It was merged by nbianca.
