FIX: do not stop `fix_missing_s3` task if saving an upload failed (PR #13658)
This commit logs an error and moves to next upload when saving a single upload record fails when running uploads:fix_missing_s3 task.
GitHub
        upload.assign_attributes(etag: fixed_upload.etag, url: fixed_upload.url, verification_status: Upload.verification_statuses[:unchecked])
        saved = upload.save(validate: false)
(then invert the if block below using the saved var)
Made the change.
