FIX: don't blow up trying to replace spoiler with post url when post is nil
FIX: don’t blow up trying to replace spoiler with post url when post is nil
I think this can be avoided by fixing this in discourse core by maing email_excerpt accepts an optional post param https://github.com/discourse/discourse/blob/08371db0cc2581bf054734b6f31fe752e8d5c945/app/helpers/user_notifications_helper.rb#L54
Will send a PR for this ^^^
index db2f124..98fdc82 100644
--- a/plugin.rb
+++ b/plugin.rb
@@ -15,6 +15,10 @@ after_initialize do
   on(:reduce_cooked) do |fragment, post|
     fragment.css(".spoiler").each do |el|
+      if !post
+        el.inner_html = I18n.t("spoiler_alert.excerpt_spoiler")
+        next
+      end
       link = fragment.document.create_element("a")
       link["href"] = post.url
       link.content = I18n.t("spoiler_alert.excerpt_spoiler")
diff --git a/spec/pretty_text_spec.rb b/spec/pretty_text_spec.rb
index 37babd4..a20fc9e 100644
--- a/spec/pretty_text_spec.rb
+++ b/spec/pretty_text_spec.rb
@@ -31,4 +31,12 @@ describe PrettyText do
     expect(md).to eq(html)
+  it 'doesn\'t blow up when post is nil' do
+    md = PrettyText.cook('I like watching [spoiler]my tests fail[/spoiler]')
+    md = PrettyText.format_for_email(md, nil)
+    html = "<p>I like watching <span class=\"spoiler\">spoiler</span></p>"
+    expect(md).to eq(html)
+  end
GitHub sha: a1ce55b7
I think we should revert that and let it blow up so that we can find all the calls that needs to be fixed.
Sure, will revert now
This PR should fix the root cause in core: Make `email_excerpt` method take an optional `post` param by OsamaSayegh · Pull Request #7570 · discourse/discourse · GitHub. I searched through the code base and I think I’ve covered all possible cases that could trigger this error.
Revert "FIX: don't blow up trying to replace spoiler with post url when post is"
We have this failing on a customer site now …
format_for_email is called without post at least in one spot
@OsamaSayegh already fixed it in
