FIX: Don't load images that don't exist in test
FIX: Don’t load images that don’t exist in test
This makes 404 requests and fills up the logs with junk
diff --git a/test/javascripts/acceptance/composer-test.js b/test/javascripts/acceptance/composer-test.js
index 9d246cd..235236a 100644
--- a/test/javascripts/acceptance/composer-test.js
+++ b/test/javascripts/acceptance/composer-test.js
@@ -112,7 +112,7 @@ QUnit.test("Composer upload placeholder", async assert => {
       original_filename: "test.png",
       thumbnail_width: 200,
       thumbnail_height: 300,
-      url: "/uploads/test1.ext"
+      url: "/images/avatar.png?1"
@@ -124,7 +124,7 @@ QUnit.test("Composer upload placeholder", async assert => {
       thumbnail_width: 100,
       thumbnail_height: 200,
-      url: "/uploads/test2.ext"
+      url: "/images/avatar.png?2"
@@ -136,7 +136,7 @@ QUnit.test("Composer upload placeholder", async assert => {
       original_filename: "image.png",
       thumbnail_width: 300,
       thumbnail_height: 400,
-      url: "/uploads/test3.ext"
+      url: "/images/avatar.png?3"
@@ -148,7 +148,7 @@ QUnit.test("Composer upload placeholder", async assert => {
       original_filename: "ima++ge.png",
@@ -177,19 +177,19 @@ QUnit.test("Composer upload placeholder", async assert => {
   await find(".wmd-controls").trigger("fileuploaddone", data2);
   assert.equal(
     find(".d-editor-input").val(),
-    "[Uploading: test.png...]() ![test|100x200](/uploads/test2.ext) [Uploading: ima++ge.png...]() [Uploading: image.png...]() "
+    "[Uploading: test.png...]() ![test|100x200](/images/avatar.png?2) [Uploading: ima++ge.png...]() [Uploading: image.png...]() "
   await find(".wmd-controls").trigger("fileuploaddone", data3);
   assert.equal(
-    "[Uploading: test.png...]() ![test|100x200](/uploads/test2.ext) [Uploading: ima++ge.png...]() ![image|300x400](/uploads/test3.ext) "
+    "[Uploading: test.png...]() ![test|100x200](/images/avatar.png?2) [Uploading: ima++ge.png...]() ![image|300x400](/images/avatar.png?3) "
   await find(".wmd-controls").trigger("fileuploaddone", data1);
   assert.equal(
-    "![test|200x300](/uploads/test1.ext) ![test|100x200](/uploads/test2.ext) [Uploading: ima++ge.png...]() ![image|300x400](/uploads/test3.ext) "
+    "![test|200x300](/images/avatar.png?1) ![test|100x200](/images/avatar.png?2) [Uploading: ima++ge.png...]() ![image|300x400](/images/avatar.png?3) "
@@ -760,7 +760,7 @@ QUnit.test("Image resizing buttons", async assert => {
     // 4 Wrapped in backquetes should not work
     "`![test|690x313](upload://test.png)`",
     // 5 html image - should not work
-    "<img src='http://someimage.jpg' wight='20' height='20'>",
+    "<img src='/images/avatar.png' wight='20' height='20'>",
     // 6 two images one the same line, but both are syntactically correct - both should work
     "![onTheSameLine1|200x200](upload://onTheSameLine1.jpeg) ![onTheSameLine2|250x250](upload://onTheSameLine2.jpeg)",
     // 7 & 8 Identical images - both should work
@@ -771,7 +771,7 @@ QUnit.test("Image resizing buttons", async assert => {
     // 10 Image with markdown title - should work
     `![image|690x220](upload://test.png "image title")`,
     // 11 bbcode - should not work
-    "[img]http://example.com/image.jpg[/img]",
+    "[img]/images/avatar.png[/img]",
     // 12 Image with data attributes
     "![test|foo=bar|690x313,50%|bar=baz](upload://test.png)"
diff --git a/test/javascripts/components/cook-text-test.js b/test/javascripts/components/cook-text-test.js
index b11019a..517a273 100644
--- a/test/javascripts/components/cook-text-test.js
+++ b/test/javascripts/components/cook-text-test.js
@@ -24,8 +24,8 @@ componentTest("resolves short URLs", {
             short_url: "upload://a.png",
-            url: "/uploads/default/original/3X/c/b/1.png",
-            short_path: "/uploads/short-url/a.png"
+            url: "/images/avatar.png",
+            short_path: "/images/d-logo-sketch.png"
@@ -38,9 +38,6 @@ componentTest("resolves short URLs", {
   test(assert) {
     const html = find(".post-body")[0].innerHTML.trim();
-    assert.equal(
-      html,
-      '<p><img src="/uploads/default/original/3X/c/b/1.png" alt="an image"></p>'
+    assert.equal(html, '<p><img src="/images/avatar.png" alt="an image"></p>');
diff --git a/test/javascripts/helpers/create-pretender.js b/test/javascripts/helpers/create-pretender.js
index c47d5c8..050b00d 100644
--- a/test/javascripts/helpers/create-pretender.js
+++ b/test/javascripts/helpers/create-pretender.js
@@ -814,7 +814,7 @@ export function applyDefaultHandlers(pretender) {
           <a href="http://test.com/somepage" target="_blank">test.com</a>
       </header>
       <article class="onebox-body">
-      <div class="aspect-image" style="--aspect-ratio:690/362;"><img src="https://test.com/image.png" class="thumbnail"></div>
+      <div class="aspect-image" style="--aspect-ratio:690/362;"><img src="" class="thumbnail"></div>
       <h3><a href="http://test.com/somepage" target="_blank">Test Page</a></h3>
       <p>Yet another collaboration tool</p>
       </article>
diff --git a/test/javascripts/lib/oneboxer-test.js b/test/javascripts/lib/oneboxer-test.js
index 22e86e9..8fe25ca 100644
--- a/test/javascripts/lib/oneboxer-test.js
+++ b/test/javascripts/lib/oneboxer-test.js
@@ -41,7 +41,7 @@ QUnit.test("load - successful onebox", async assert => {
       </header>
       </article>
diff --git a/test/javascripts/lib/upload-short-url-test.js b/test/javascripts/lib/upload-short-url-test.js
index cbd02d9..7c9248e 100644
--- a/test/javascripts/lib/upload-short-url-test.js
+++ b/test/javascripts/lib/upload-short-url-test.js
@@ -15,17 +15,17 @@ function stubUrls(imageSrcs, attachmentSrcs, otherMediaSrcs) {
     imageSrcs = [
         short_url: "upload://a.jpeg",
-        url: "/uploads/default/original/3X/c/b/1.jpeg",
+        url: "/images/avatar.png?a",
         short_path: "/uploads/short-url/a.jpeg"
         short_url: "upload://b.jpeg",
-        url: "/uploads/default/original/3X/c/b/2.jpeg",
+        url: "/images/avatar.png?b",
         short_path: "/uploads/short-url/b.jpeg"
         short_url: "upload://z.jpeg",
-        url: "/uploads/default/original/3X/c/b/9.jpeg",
+        url: "/images/avatar.png?z",
         short_path: "/uploads/short-url/z.jpeg"
@@ -89,14 +89,14 @@ QUnit.test("resolveAllShortUrls", async assert => {
   lookup = lookupCachedUploadUrl("upload://a.jpeg");
   assert.deepEqual(lookup, {
   lookup = lookupCachedUploadUrl("upload://b.jpeg");
@@ -136,8 +136,8 @@ QUnit.test(
       .eq(1);
     let link = fixture().find("a");
-    assert.equal(image1.attr("src"), "/uploads/default/original/3X/c/b/1.jpeg");
-    assert.equal(image2.attr("src"), "/uploads/default/original/3X/c/b/2.jpeg");
+    assert.equal(image1.attr("src"), "/images/avatar.png?a");
GitHub sha: f68ea292
