FIX: Don't print error message from which when checking docker install (#549)
FIX: Don’t print error message from which when checking docker install (#549)
‘which docker.io || which docker’ prints an error message when docker.io is missing, which will be the case on any non-Ubuntu-based system. This is confusing and not actually an error unless both are missing.
diff --git a/discourse-setup b/discourse-setup
index e9537f2..3548feb 100755
--- a/discourse-setup
+++ b/discourse-setup
@@ -123,15 +123,16 @@ check_IP_match() {
 ## Do we have docker?
 check_and_install_docker () {
-  docker_path=`which docker.io || which docker`
-  if [ -z $docker_path ]; then
-    read  -p "Docker not installed. Enter to install from https://get.docker.com/ or Ctrl+C to exit"
+  if ! which docker.io docker 2>/dev/null ; then
+    echo Failed to find docker.io or docker on your PATH.
+    read -p "Enter to install Docker from https://get.docker.com/ or Ctrl+C to exit"
     curl https://get.docker.com/ | sh
-  fi
-    echo Docker install failed. Quitting.
-    exit
+      echo Still failed to find docker.io or docker on your PATH.
+      echo Docker install failed. Quitting.
+      exit
+    fi
   fi
GitHub sha: 994922639b5dd20b78ef45888b854632980d2cfd
This commit appears in #549 which was approved by SamSaffron. It was merged by SamSaffron.
