FIX: Don't send extra_data when exporting results to JSON
FIX: Don’t send extra_data when exporting results to JSON
The extra data is needed to render avatars and user metadata when rendering results in the browser, we can skip this data for JSON exports to reduce bloat
index e67cb0e..8f86bc0 100644
--- a/plugin.rb
+++ b/plugin.rb
@@ -1115,9 +1115,12 @@ SQL
               default_limit: DataExplorer::QUERY_RESULT_MAX_LIMIT
             json[:explain] = result[:explain] if opts[:explain]
-            ext = DataExplorer.add_extra_data(pg_result)
-            json[:colrender] = ext[1]
-            json[:relations] = ext[0]
+            if !params[:download]
+              ext = DataExplorer.add_extra_data(pg_result)
+              json[:colrender] = ext[1]
+              json[:relations] = ext[0]
+            end
             json[:rows] = pg_result.values
GitHub sha: a3c9cd73
