FIX: Don't treat 'upload_patterns' as constant to make the rake task compatible with multisite
FIX: Don’t treat ‘upload_patterns’ as constant to make the rake task compatible with multisite
index a783adf..c3d07af 100644
--- a/Gemfile.lock
+++ b/Gemfile.lock
@@ -570,4 +570,4 @@ DEPENDENCIES
   webpush
 BUNDLED WITH
-   1.17.3
+   2.0.1
diff --git a/lib/tasks/posts.rake b/lib/tasks/posts.rake
index dfca963..0bde9b5 100644
--- a/lib/tasks/posts.rake
+++ b/lib/tasks/posts.rake
@@ -390,12 +390,6 @@ task 'posts:reorder_posts', [:topic_id] => [:environment] do |_, args|
   puts "", "Done.", ""
-UPLOAD_PATTERNS ||= [
-  /\/uploads\/#{RailsMultisite::ConnectionManagement.current_db}\//,
-  /\/original\//,
-  /\/optimized\//
-].freeze
 def get_missing_uploads
   PostCustomField.where(name: Post::MISSING_UPLOADS)
@@ -403,6 +397,12 @@ end
 desc 'Finds missing post upload records from cooked HTML content'
 task 'posts:missing_uploads' => :environment do
   get_missing_uploads.delete_all
+  upload_patterns = [
+    /\/uploads\/#{RailsMultisite::ConnectionManagement.current_db}\//,
+    /\/original\//,
+    /\/optimized\//
   missing_uploads = []
   old_scheme_upload_count = 0
   count = 0
@@ -416,7 +416,7 @@ task 'posts:missing_uploads' => :environment do
       Nokogiri::HTML::fragment(post.cooked).css("a/@href", "img/@src").each do |media|
         src = media.value
-        next if src.blank? || UPLOAD_PATTERNS.none? { |pattern| src =~ pattern }
+        next if src.blank? || upload_patterns.none? { |pattern| src =~ pattern }
         src = "#{SiteSetting.force_https ? "https" : "http"}:#{src}" if src.start_with?("//")
         next unless Discourse.store.has_been_uploaded?(src) || src =~ /\A\/[^\/]/i
GitHub sha: aed68339
Did you mean to update that?
