FIX: downsize_uploads script to support external storage
Also ensured we update the sha1 property of the upload record to match the actual file.
diff --git a/script/downsize_uploads.rb b/script/downsize_uploads.rb
index cd67d10..27a2555 100644
--- a/script/downsize_uploads.rb
+++ b/script/downsize_uploads.rb
@@ -9,28 +9,30 @@ puts '', "Downsizing uploads size to no more than #{max_image_pixels} pixels"
 count = 0
-Upload.where("lower(extension) in (?)", ['jpg', 'jpeg', 'gif', 'png']).find_each do |upload|
+Upload.where("LOWER(extension) IN ('jpg', 'jpeg', 'gif', 'png')").find_each do |upload|
   count += 1
   print "\r%8d".freeze % count
-  absolute_path = Discourse.store.path_for(upload)
-  if absolute_path && FileHelper.is_supported_image?(upload.original_filename)
-    file = File.new(absolute_path) rescue nil
-    next unless file
-    image_info = FastImage.new(file) rescue nil
-    pixels = image_info.size&.reduce(:*).to_i
+  next unless source = upload.local? ? Discourse.store.path_for(upload) : "https:#{upload.url}"
+  next unless size = (FastImage.size(source) rescue nil)
+  next if size.reduce(:*) < max_image_pixels
+  next unless path = upload.local? ? source : (Discourse.store.download(upload) rescue nil)&.path
-    if pixels > max_image_pixels
-      OptimizedImage.downsize(file.path, file.path, "#{max_image_pixels}@", filename: upload.original_filename)
+  OptimizedImage.downsize(path, path, "#{max_image_pixels}@", filename: upload.original_filename)
-      upload.filesize = File.size(file)
-      upload.width, upload.height = ImageSizer.resize(*FastImage.new(file).size)
-      upload.save!
+  previous_short_url = upload.short_url
-      upload.posts.each do |post|
-        Jobs.enqueue(:process_post, post_id: post.id, bypass_bump: true, cook: true)
-      end
-    end
+  upload.filesize = File.size(path)
+  upload.sha1 = Upload.generate_digest(path)
+  upload.width, upload.height = ImageSizer.resize(*FastImage.size(path))
+  next unless upload.save!
+  next unless url = Discourse.store.store_upload(File.new(path), upload)
+  next unless upload.update!(url: url)
+  upload.posts.each do |post|
+    post.update!(raw: post.raw.gsub(previous_short_url, upload.short_url))
+    Jobs.enqueue(:process_post, post_id: post.id, bypass_bump: true, cook: true)
GitHub sha: 4fdad129
