FIX: Drop readonly function when dropping table
diff --git a/lib/migration/table_dropper.rb b/lib/migration/table_dropper.rb
index d710b88..8b7e89a 100644
--- a/lib/migration/table_dropper.rb
+++ b/lib/migration/table_dropper.rb
@@ -18,6 +18,7 @@ module Migration
     def self.execute_drop(table_name)
       DB.exec("DROP TABLE IF EXISTS #{table_name}")
+      BaseDropper.drop_readonly_function(table_name)
diff --git a/spec/components/migration/table_dropper_spec.rb b/spec/components/migration/table_dropper_spec.rb
index 2f1d221..a59da8b 100644
--- a/spec/components/migration/table_dropper_spec.rb
+++ b/spec/components/migration/table_dropper_spec.rb
@@ -14,6 +14,16 @@ describe Migration::TableDropper do
     SQL
+  def function_exists?(function_name, schema_name = 'public')
+    DB.exec(<<~SQL) > 0
+      SELECT 1
+      FROM information_schema.routines
+      WHERE routine_type = 'FUNCTION' AND
+            routine_name = '#{function_name}' AND
+            specific_schema = '#{schema_name}'
+    SQL
+  end
   let(:table_name) { 'table_with_old_name' }
   before do
@@ -56,6 +66,16 @@ describe Migration::TableDropper do
       expect(table_exists?(table_name)).to eq(false)
+    it "should drop the read_only function" do
+      Migration::TableDropper.execute_drop(table_name)
+      schema_name, function_name = Migration::BaseDropper
+        .readonly_function_name(table_name)
+        .delete_suffix('()').split('.')
+      expect(function_exists?(function_name, schema_name)).to eq(false)
+    end
     it 'should prevent insertions to the table' do
       begin
         DB.exec <<~SQL
GitHub sha: 74d78e36
