FIX: ensures backward compat with previous findRawTemplate (#48)
To my knowledge we don’t implement requirejs.defined so I rely on the __DISCOURSE_RAW_TEMPLATES constant which has been introduced in the commit where we moved from discourse/lib/raw-template to discourse-common/lib/raw-templates.
diff --git a/assets/javascripts/discourse/components/query-result.js.es6 b/assets/javascripts/discourse/components/query-result.js.es6
index 0eb4ab2..51dab5d 100644
--- a/assets/javascripts/discourse/components/query-result.js.es6
+++ b/assets/javascripts/discourse/components/query-result.js.es6
@@ -1,6 +1,5 @@
 import { ajax } from "discourse/lib/ajax";
 import Badge from "discourse/models/badge";
-import { getOwner } from "discourse-common/lib/get-owner";
 import { default as computed } from "discourse-common/utils/decorators";
 function randomIdShort() {
@@ -32,6 +31,22 @@ const QueryResultComponent = Ember.Component.extend({
   explainText: Ember.computed.alias("content.explain"),
   hasExplain: Ember.computed.notEmpty("content.explain"),
+  init() {
+    this._super(...arguments);
+    // TODO: After `__DISCOURSE_RAW_TEMPLATES` is in stable this should be updated
+    // to use only `import { findRawTemplate } from "discourse-common/lib/raw-templates"`
+    if (window.__DISCOURSE_RAW_TEMPLATES) {
+      this.findRawTemplate = requirejs(
+        "discourse-common/lib/raw-templates"
+      ).findRawTemplate;
+    } else {
+        "discourse/lib/raw-templates"
   @computed("content.result_count")
   resultCount(count) {
     if (count === this.get("content.default_limit")) {
@@ -80,7 +95,7 @@ const QueryResultComponent = Ember.Component.extend({
   @computed
   fallbackTemplate() {
-    return getOwner(this).lookup("template:explorer/text.raw");
+    return this.findRawTemplate("javascripts/explorer/text");
   @computed("content", "columns.[]")
@@ -94,11 +109,7 @@ const QueryResultComponent = Ember.Component.extend({
         viewName = this.get("content.colrender")[idx];
-      // After `findRawTemplates` is in stable this should be updated to use that
-      let template = getOwner(this).lookup(`template:explorer/${viewName}.raw`);
-      if (!template) {
-        template = Discourse.RAW_TEMPLATES[`javascripts/explorer/${viewName}`];
+      const template = this.findRawTemplate(`javascripts/explorer/${viewName}`);
       return { name: viewName, template };
GitHub sha: 92978856
This commit appears in #48 which was approved by eviltrout. It was merged by jjaffeux.
