FIX: ensures custom fields work when using _ in the name
diff --git a/assets/javascripts/lib/raw-event-helper.js.es6 b/assets/javascripts/lib/raw-event-helper.js.es6
index a1377c1..bc4bbde 100644
--- a/assets/javascripts/lib/raw-event-helper.js.es6
+++ b/assets/javascripts/lib/raw-event-helper.js.es6
@@ -87,7 +87,10 @@ export function replaceRaw(params, raw) {
 function camelCase(input) {
-  return input.toLowerCase().replace(/-(.)/g, function (match, group1) {
-    return group1.toUpperCase();
+  return input
+    .toLowerCase()
+    .replace(/_/g, "-")
+    .replace(/-(.)/g, function (match, group1) {
+      return group1.toUpperCase();
GitHub sha: 57f12f36
