FIX: ensures we check on op and not any post
index 916d359..0ecfa54 100644
--- a/plugin.rb
+++ b/plugin.rb
@@ -124,10 +124,14 @@ after_initialize do
   validate(:post, :validate_post) do |force = nil|
-    return if !self.custom_fields[DiscourseCalendar::CALENDAR_CUSTOM_FIELD]
     return unless self.raw_changed? || force
     return if self.is_first_post?
+    op = self&.topic&.first_post
+    if op && op&.custom_fields
+      return if !op.custom_fields[DiscourseCalendar::CALENDAR_CUSTOM_FIELD]
+    end
     validator = DiscourseCalendar::EventValidator.new(self)
     validator.validate_event
GitHub sha: 8cbb3c66
Can be shortened to
if op&.custom_fields
oh yes I changed it after… wasn’t using & at first :frowning:
thanks
