FIX: Error message when setting enforce 2fa with social logins (#10479)
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index 684d96b..61f2214 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -193,6 +193,7 @@ en:
       s3_bucket_reused: "You cannot use the same bucket for 's3_upload_bucket' and 's3_backup_bucket'. Choose a different bucket or use a different path for each bucket."
       secure_media_requirements: "S3 uploads must be enabled before enabling secure media."
       share_quote_facebook_requirements: "You must set a Facebook app id to enable quote sharing for Facebook."
+      second_factor_cannot_enforce_with_socials: "You cannot enforce 2FA with social logins enabled. You must first disable login via: %{auth_provider_names}"
       second_factor_cannot_be_enforced_with_disabled_local_login: "You cannot enforce 2FA if local logins are disabled."
       local_login_cannot_be_disabled_if_second_factor_enforced: "You cannot disable local login if 2FA is enforced. Disable enforced 2FA before disabling local logins."
       cannot_enable_s3_uploads_when_s3_enabled_globally: "You cannot enable S3 uploads because S3 uploads are already globally enabled, and enabling this site-level could cause critical issues with uploads"
diff --git a/lib/site_settings/validations.rb b/lib/site_settings/validations.rb
index 4160a17..55da27c 100644
--- a/lib/site_settings/validations.rb
+++ b/lib/site_settings/validations.rb
@@ -156,6 +156,10 @@ module SiteSettings::Validations
   def validate_enforce_second_factor(new_val)
+    if new_val == "all" && Discourse.enabled_auth_providers.count > 0
+      auth_provider_names = Discourse.enabled_auth_providers.map(&:name).join(", ")
+      return validate_error(:second_factor_cannot_enforce_with_socials, auth_provider_names: auth_provider_names)
+    end
     return if SiteSetting.enable_local_logins
     return if new_val == "no"
     validate_error :second_factor_cannot_be_enforced_with_disabled_local_login
diff --git a/spec/lib/site_settings/validations_spec.rb b/spec/lib/site_settings/validations_spec.rb
index 69ab739..420e8f4 100644
--- a/spec/lib/site_settings/validations_spec.rb
+++ b/spec/lib/site_settings/validations_spec.rb
@@ -115,10 +115,10 @@ describe SiteSettings::Validations do
-  describe "enforce second factor & local login interplay" do
+  describe "enforce second factor & local/auth provider login interplay" do
     describe "#validate_enforce_second_factor" do
-      let(:error_message) { I18n.t("errors.site_settings.second_factor_cannot_be_enforced_with_disabled_local_login") }
       context "when local logins are disabled" do
+        let(:error_message) { I18n.t("errors.site_settings.second_factor_cannot_be_enforced_with_disabled_local_login") }
         before do
           SiteSetting.enable_local_logins = false
@@ -137,6 +137,18 @@ describe SiteSettings::Validations do
           expect { subject.validate_enforce_second_factor("t") }.not_to raise_error
+      context "when social logins are enabled" do
+        let(:error_message) { I18n.t("errors.site_settings.second_factor_cannot_enforce_with_socials", auth_provider_names: "facebook, github") }
+        before do
+          SiteSetting.enable_facebook_logins = true
+          SiteSetting.enable_github_logins = true
+        end
+        it "raises and error, and specifies the auth providers" do
+          expect { subject.validate_enforce_second_factor("all") }.to raise_error(Discourse::InvalidParameters, error_message)
+        end
+      end
     describe "#validate_enable_local_logins" do
GitHub sha: a3c0d4a8
This commit appears in #10479 which was approved by eviltrout. It was merged by markvanlan.
