Fix error when default_categories_muted includes deleted categories
diff --git a/lib/discourse_code_review/state/github_repo_categories.rb b/lib/discourse_code_review/state/github_repo_categories.rb
index 99bb05e..bec073a 100644
--- a/lib/discourse_code_review/state/github_repo_categories.rb
+++ b/lib/discourse_code_review/state/github_repo_categories.rb
@@ -30,7 +30,8 @@ module DiscourseCodeReview::State::GithubRepoCategories
           category.save!
           if SiteSetting.code_review_default_mute_new_categories
-            SiteSetting.default_categories_muted = (SiteSetting.default_categories_muted.split("|") << category.id).join("|")
+            existing_category_ids = Category.where(id: SiteSetting.default_categories_muted.split("|")).pluck(:id)
+            SiteSetting.default_categories_muted = (existing_category_ids << category.id).join("|")
           category.custom_fields[GITHUB_REPO_NAME] = repo_name
diff --git a/spec/discourse_code_review/lib/state/github_repo_categories_spec.rb b/spec/discourse_code_review/lib/state/github_repo_categories_spec.rb
new file mode 100644
index 0000000..805df7f
--- /dev/null
+++ b/spec/discourse_code_review/lib/state/github_repo_categories_spec.rb
@@ -0,0 +1,47 @@
+require "rails_helper"
+describe DiscourseCodeReview::State::GithubRepoCategories do
+  it "can create a new category" do
+    expect {
+      c = described_class.ensure_category(repo_name: "repo-name")
+      expect(c.name).to eq("repo-name")
+      expect(c.custom_fields[DiscourseCodeReview::State::GithubRepoCategories::GITHUB_REPO_NAME]).to eq("repo-name")
+    }.to change { Category.count }.by(1)
+  end
+  it "can use an existing category" do
+    c = Fabricate(:category, name: "repo-name")
+    c.custom_fields[DiscourseCodeReview::State::GithubRepoCategories::GITHUB_REPO_NAME] = "repo-name"
+    c.save_custom_fields
+    expect {
+    }.to_not change { Category.count }
+  end
+  context "code_review_default_mute_new_categories enabled" do
+    before do
+      SiteSetting.code_review_default_mute_new_categories = true
+    end
+    it "can add the category" do
+      expect(SiteSetting.default_categories_muted).to eq(c.id.to_s)
+      c2 = described_class.ensure_category(repo_name: "repo-name2")
+      expect(SiteSetting.default_categories_muted.split("|").map(&:to_i)).to contain_exactly(c.id, c2.id)
+    end
+    it "removes categories that were deleted" do
+      c.destroy
+      expect(SiteSetting.default_categories_muted.split("|").map(&:to_i)).to contain_exactly(c2.id)
+    end
+  end
+end
GitHub sha: 78cdaee9
