FIX: Expose `rails_multisite` connection handlers to ActiveRecord.
FIX: Expose rails_multisite connection handlers to ActiveRecord.
In Rails 6, switching between writing and reading roles are done using connection handlers. This commit prepares us for Rails 6.1 which will land with sharding support.
diff --git a/lib/rails_multisite/connection_management.rb b/lib/rails_multisite/connection_management.rb
index 8baf9ff..7b03be5 100644
--- a/lib/rails_multisite/connection_management.rb
+++ b/lib/rails_multisite/connection_management.rb
@@ -11,6 +11,10 @@ module RailsMultisite
     def self.clear_settings!
+      @instance&.db_spec_cache&.each do |key, spec|
+        @instance.connection_handlers.delete(self.handler_key(spec))
+      end
       @instance = nil
@@ -121,14 +125,32 @@ module RailsMultisite
-    attr_reader :config_filename
+    def self.handler_key(spec)
+      @handler_key_suffix ||= begin
+        if ActiveRecord::Base.respond_to?(:writing_role)
+          "_#{ActiveRecord::Base.writing_role}"
+        else
+        end
+      end
+      :"#{spec.name}#{@handler_key_suffix}"
+    end
+    attr_reader :config_filename, :db_spec_cache, :connection_handlers
     def initialize(config_filename)
       @config_filename = config_filename
-      @connection_handlers = {}
-      @db_spec_cache = {}
+      @connection_handlers = begin
+        if ActiveRecord::Base.respond_to?(:connection_handlers)
+          ActiveRecord::Base.connection_handlers
+        else
+        end
+      end
+      @db_spec_cache = {}
       @default_spec = SPEC_KLASS::Resolver.new(ActiveRecord::Base.configurations).spec(Rails.env.to_sym)
       @default_connection_handler = ActiveRecord::Base.connection_handler
       @established_default = false
@@ -188,8 +210,7 @@ module RailsMultisite
       @db_spec_cache = new_db_spec_cache
       # Clean up connection handler cache.
-      # (@connection_handlers is a hash of spec => handler)
-      removed_specs.each { |s| @connection_handlers.delete(s) }
+      removed_specs.each { |s| @connection_handlers.delete(handler_key(s)) }
     def reload
@@ -217,11 +238,11 @@ module RailsMultisite
       spec ||= @default_spec
       handler = nil
       if spec != @default_spec
-        handler = @connection_handlers[spec]
+        handler = @connection_handlers[handler_key(spec)]
         unless handler
           handler = ActiveRecord::ConnectionAdapters::ConnectionHandler.new
           handler_establish_connection(handler, spec)
-          @connection_handlers[spec] = handler
+          @connection_handlers[handler_key(spec)] = handler
       else
         handler = @default_connection_handler
@@ -362,5 +383,9 @@ module RailsMultisite
       handler.establish_connection(spec.config)
+    def handler_key(spec)
+      self.class.handler_key(spec)
+    end
GitHub sha: 2a865f80
This commit appears in #14 which was merged by tgxworld.
