FIX: first post true if user creates topic first (#8139)
Reported here: User was banned for posting a reply within 3 seconds - support - Discourse Meta The problem here is the user could create a topic, then reply and get silenced on the second time (though technically their first post) for being below the min_first_post_typing_time threshold.
diff --git a/lib/new_post_manager.rb b/lib/new_post_manager.rb
index c047b78..aee243b 100644
--- a/lib/new_post_manager.rb
+++ b/lib/new_post_manager.rb
@@ -40,7 +40,8 @@ class NewPostManager
       args[:first_post_checks] &&
-      user.post_count == 0
+      user.post_count == 0 &&
+      user.topic_count == 0
diff --git a/spec/requests/posts_controller_spec.rb b/spec/requests/posts_controller_spec.rb
index 7e10e1a..a7e8c7d 100644
--- a/spec/requests/posts_controller_spec.rb
+++ b/spec/requests/posts_controller_spec.rb
@@ -859,6 +859,23 @@ describe PostsController do
           expect(user).not_to be_silenced
+        it "doesn't enqueue posts when user first creates a topic" do
+          user.user_stat.update_column(:topic_count, 1)
+          post "/posts.json", params: {
+            raw: 'this is the test content',
+            title: 'this is the test title for the topic',
+            composer_open_duration_msecs: 204,
+            typing_duration_msecs: 100,
+            topic_id: topic.id
+          expect(response.status).to eq(200)
+          parsed = ::JSON.parse(response.body)
+          expect(parsed["action"]).not_to be_present
+        end
         it "doesn't enqueue replies when the topic is closed" do
           topic = Fabricate(:closed_topic)
GitHub sha: 63fabdb6
