FIX: Fix build.
FIX: Fix build.
Follow-up to 25453eb.
diff --git a/lib/json_error.rb b/lib/json_error.rb
index 9518ece..ac6ff76 100644
--- a/lib/json_error.rb
+++ b/lib/json_error.rb
@@ -32,7 +32,7 @@ module JsonError
       return { errors: [message] } if message.present?
-    return { errors: [I18n.t('not_found')] } if obj.not_found
+    return { errors: [I18n.t('not_found')] } if obj.is_a?(HasErrors) && obj.not_found
     # Log a warning (unless obj is nil)
     Rails.logger.warn("create_errors_json called with unrecognized type: #{obj.inspect}") if obj
GitHub sha: 631b16ef
