FIX: Fix image optimization pipeline (#9257)
  • FIX: Do not use original filename to extract the original filename
Prefer extracting filename from the destination path, which is build using extracted image information.
  • UX: Show better error images
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index 6d1c849..986905f 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -3734,6 +3734,7 @@ en:
     file_missing: "Sorry, you must provide a file to upload."
     empty: "Sorry, but the file you provided is empty."
     png_to_jpg_conversion_failure_message: "An error happened when converting from PNG to JPG."
+    optimize_failure_message: "An error occured while optimizing the uploaded image."
       too_large: "Sorry, the file you are trying to upload is too big (maximum size is %{max_size_kb}KB)."
     images:
diff --git a/lib/upload_creator.rb b/lib/upload_creator.rb
index 9c66754..d9c21f1 100644
--- a/lib/upload_creator.rb
+++ b/lib/upload_creator.rb
@@ -252,7 +252,6 @@ class UploadCreator
         from,
         to,
         "50%",
-        filename: @filename,
         allow_animation: allow_animation,
         raise_on_error: true
@@ -264,6 +263,8 @@ class UploadCreator
       return if filesize >= original_size || pixels == 0 || !should_downsize?
+  rescue
+    @upload.errors.add(:base, I18n.t("upload.optimize_failure_message"))
   def is_still_too_big?
GitHub sha: 49395ec5
This commit appears in #9257 which was approved by eviltrout. It was merged by udan11.
