FIX: Fix test suite after fabricated category defaults changed
Categories no longer create definition topics by default
diff --git a/spec/integration/solved_spec.rb b/spec/integration/solved_spec.rb
index 5d47aca..a3451eb 100644
--- a/spec/integration/solved_spec.rb
+++ b/spec/integration/solved_spec.rb
@@ -13,7 +13,7 @@ RSpec.describe "Managing Posts solved status" do
   describe 'auto bump' do
     it 'does not automatically bump solved topics' do
-      category = Fabricate(:category)
+      category = Fabricate(:category_with_definition)
       post = create_post(category: category)
       post2 = create_post(category: category)
GitHub sha: a58984bf
