FIX: Fixed deleted posts layout (#7348)
diff --git a/app/assets/javascripts/discourse/components/user-stream.js.es6 b/app/assets/javascripts/discourse/components/user-stream.js.es6
index 9060022..be0ba24 100644
--- a/app/assets/javascripts/discourse/components/user-stream.js.es6
+++ b/app/assets/javascripts/discourse/components/user-stream.js.es6
@@ -8,6 +8,16 @@ import { popupAjaxError } from "discourse/lib/ajax-error";
 import { getOwner } from "discourse-common/lib/get-owner";
 export default Ember.Component.extend(LoadMore, {
+  _initialize: function() {
+    const filter = this.get("stream.filter");
+    if (filter) {
+      this.set("classNames", [
+        "user-stream",
+        "filter-" + filter.toString().replace(",", "-")
+  }.on("init"),
   loading: false,
   eyelineSelector: ".user-stream .item",
   classNames: ["user-stream"],
diff --git a/app/assets/javascripts/discourse/templates/user.hbs b/app/assets/javascripts/discourse/templates/user.hbs
index 765b011..afee93b 100644
--- a/app/assets/javascripts/discourse/templates/user.hbs
+++ b/app/assets/javascripts/discourse/templates/user.hbs
@@ -193,7 +193,7 @@
             {{/if}}
             {{#if canDeleteUser}}
-              <div>{{d-button action=(action "adminDelete") icon="exclamation-triangle" label="user.admin_delete" class="btn-danger"}}</div>
+              <div class='pull-right'>{{d-button action=(action "adminDelete") icon="exclamation-triangle" label="user.admin_delete" class="btn-danger"}}</div>
             {{/if}}
           </dl>
           {{plugin-outlet name="user-profile-secondary" args=(hash model=model)}}
diff --git a/app/assets/stylesheets/common/components/user-stream.scss b/app/assets/stylesheets/common/components/user-stream.scss
new file mode 100644
index 0000000..56ab2a9
--- /dev/null
+++ b/app/assets/stylesheets/common/components/user-stream.scss
@@ -0,0 +1,7 @@
+.user-stream {
+  &.filter-deleted {
+    grid-column-start: 1;
+    grid-column-end: 3;
+    grid-row-start: 2;
diff --git a/test/javascripts/acceptance/user-anonymous-test.js.es6 b/test/javascripts/acceptance/user-anonymous-test.js.es6
index f187914..2f4fbdf 100644
--- a/test/javascripts/acceptance/user-anonymous-test.js.es6
+++ b/test/javascripts/acceptance/user-anonymous-test.js.es6
@@ -27,6 +27,8 @@ QUnit.test("Filters", async assert => {
   await visit("/u/eviltrout/activity/replies");
   hasStream(assert);
+  assert.ok(exists(".user-stream.filter-5"), "stream has filter class");
 QUnit.test("Badges", async assert => {
GitHub sha: fe9c271d
