FIX: flaky groups_controller_spec (#9439)
Sometimes spec which is testing order groups by user count is failing.
My theory is that cause is the randomness of Postgres when the order value is the same for 2 rows.
In spec, we got three groups moderator_group - 0 users group - 1 user other_group - 1 user
And we are expecting that controller will return them in ascending order [moderator, group, other_group]
Because group and other_group contain the same amount of users, we are dealing with luck
Therefore, I believe that adding one more user to other_group should make that query reliable.
It was not crashing on my local machine, so I am not 100% sure.
diff --git a/spec/requests/groups_controller_spec.rb b/spec/requests/groups_controller_spec.rb
index 381e247..0f1027e 100644
--- a/spec/requests/groups_controller_spec.rb
+++ b/spec/requests/groups_controller_spec.rb
@@ -4,6 +4,7 @@ require 'rails_helper'
 describe GroupsController do
   fab!(:user) { Fabricate(:user) }
+  let(:other_user) { Fabricate(:user) }
   let(:group) { Fabricate(:group, users: [user]) }
   let(:moderator_group_id) { Group::AUTO_GROUPS[:moderators] }
   fab!(:admin) { Fabricate(:admin) }
@@ -91,7 +92,7 @@ describe GroupsController do
         sign_in(user)
-      let!(:other_group) { Fabricate(:group, name: "other_group", users: [user]) }
+      let!(:other_group) { Fabricate(:group, name: "other_group", users: [user, other_user]) }
       context "with default (descending) order" do
         it "sorts by name" do
@@ -116,7 +117,7 @@ describe GroupsController do
           body = JSON.parse(response.body)
           expect(body["groups"].map { |g| g["id"] }).to eq([
-            group.id, other_group.id, moderator_group_id
+            other_group.id, group.id, moderator_group_id
           expect(body["load_more_groups"]).to eq("/groups?order=user_count&page=1")
GitHub sha: e8e764c0
This commit appears in #9439 which was approved by eviltrout. It was merged by lis2.
